Home > Technical > Mice in the engine bay of my TD5 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5787 |
Yeah, drive belt (britpart) ones do this, if not fit a new tensioner.
Simples Andy |
9th Dec 2010 8:31pm |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
turn all your lights on, HRW etc, revv engine to see if lights brighten or squeek gets worse
9th Dec 2010 8:33pm |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
Squeak goes away when you rev it..... |
9th Dec 2010 8:34pm |
It is as if they have joined the belt on the cheap belts and the ridged join causes a sqeak.
Andy |
9th Dec 2010 8:38pm |
Cheers for the advice, will replace at the weekend. best to get genuine LR? |
9th Dec 2010 8:46pm |
yes, and keep the other as a spare so you won't need one.
Andy |
9th Dec 2010 8:47pm |
Cheers Andy, much appreciated. |
9th Dec 2010 8:51pm |
Guess: probably the belt needs a little tighten having settled in and stretched since new.
Potentially could be an oil leak dripping onto the belt.....not sure if this engine is prone - not sure I've seen any posts on such a problem |
9th Dec 2010 9:25pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
crank pulley on it's way out.
see here http://www.discovery2.co.uk/CrankPulley.html very good right up. |
9th Dec 2010 9:34pm |
just been and checked with the fan cover off. Belt looks in good condition and doesn't seem slack, 12mm of deflection exaclty. Just what the workshop manual says..........mmmmmmmmmmmm
9th Dec 2010 10:06pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
My tensioner had partly ceased and was causing my belt to squeal when starting, stopping and moving off at tick over.
Took the tensioner off and soaked it in GT85 and fitted a new Dayco belt, stopped the noise for a while but its coming back so will get a new tensioner. Pete. |
9th Dec 2010 10:28pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Spray some WD40 on it.
Works every time. |
9th Dec 2010 10:52pm |
Taking the car back to the dealer in the morning.
Couple of things, The tensioner pulley has a visible (if not significant) vibration / movement when the engine is running - is this normal? When the engine is coming up to temperature the noise starts to subside and when fully up to temperature the noise goes completely (at idle, fast idle and full load) |
10th Dec 2010 11:52am |
Just check your exhaust manifold studs while your looking around there, it would explain why the noise goes when things warm up. Had a few friends that have changed there fan belt because it squeals and it ended up being a broken or loose stud in the manifold.
Pete. |
10th Dec 2010 12:25pm |
