Home > Technical > Mice in the engine bay of my TD5
TC
Sounds like they have gotten in Exclamation
Not turned the landy over since yesterday morning. Fired the motor up this evening and I have a rather loud squeal coming from up front. Have had a look and from a first glance the fan belt looks ok.
Anyone got any other ideas? It is a fan belt kind of rhythmic squeak.....(only had it a week and this is my first Defender....please be gentle Smile )
cheers
TC
Post #48026 9th Dec 2010 8:25pm
landy andy
Yeah, Censored drive belt (britpart) ones do this, if not fit a new tensioner.
Simples
Andy
Post #48028 9th Dec 2010 8:31pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
turn all your lights on, HRW etc, revv engine to see if lights brighten or squeek gets worse
Post #48030 9th Dec 2010 8:33pm
TC
Squeak goes away when you rev it.....
Post #48031 9th Dec 2010 8:34pm
landy andy
It is as if they have joined the belt on the cheap belts and the ridged join causes a sqeak.
Andy
Post #48035 9th Dec 2010 8:38pm
TC
Andy
Cheers for the advice, will replace at the weekend. best to get genuine LR?
Post #48037 9th Dec 2010 8:46pm
landy andy
yes, and keep the other as a spare so you won't need one.
Andy
Post #48038 9th Dec 2010 8:47pm
TC
Andy
Cheers Andy, much appreciated. Thumbs Up
Post #48041 9th Dec 2010 8:51pm
SteveS
Guess: probably the belt needs a little tighten having settled in and stretched since new.
Potentially could be an oil leak dripping onto the belt.....not sure if this engine is prone - not sure I've seen any posts on such a problem
Post #48050 9th Dec 2010 9:25pm
T1G UP
crank pulley on it's way out.
see here
http://www.discovery2.co.uk/CrankPulley.html
very good right up.
Post #48053 9th Dec 2010 9:34pm
TC
just been and checked with the fan cover off. Belt looks in good condition and doesn't seem slack, 12mm of deflection exaclty. Just what the workshop manual says..........mmmmmmmmmmmm
Post #48058 9th Dec 2010 10:06pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
My tensioner had partly ceased and was causing my belt to squeal when starting, stopping and moving off at tick over.
Took the tensioner off and soaked it in GT85 and fitted a new Dayco belt, stopped the noise for a while but its coming back so will get a new tensioner.
Pete.
Post #48060 9th Dec 2010 10:28pm
Laurie
Spray some WD40 on it.
Works every time.
Post #48063 9th Dec 2010 10:52pm
TC
Taking the car back to the dealer in the morning.
Couple of things,
The tensioner pulley has a visible (if not significant) vibration / movement when the engine is running - is this normal?
When the engine is coming up to temperature the noise starts to subside and when fully up to temperature the noise goes completely (at idle, fast idle and full load)
Post #48101 10th Dec 2010 11:52am
Zinke
Just check your exhaust manifold studs while your looking around there, it would explain why the noise goes when things warm up. Had a few friends that have changed there fan belt because it squeals and it ended up being a broken or loose stud in the manifold.
Pete.
Post #48107 10th Dec 2010 12:25pm
