![]() | Home > Puma (Tdci) > Strange Noise on Starting |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2049 ![]() ![]() |
Just a guess....maybe Belt tensioner?
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Thanks Daz, will remove belt and check. But still think its related to starter.... 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1646 ![]() ![]() |
Sounds like a lazy or broken return spring on the starter motor ring gear I think...
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
There was a TSB at one time concering a recurring fault with the ignition/starter swtich, which on some vehicles was failing to disengage the starter when the engine started resulting ultimately in the destruction of the starter motor. Although I think it was pre-2010, it might be worth checking.
As far as I know, the starter is inhibited by an "ENGINE RUNNING" output from the ECU, so it is possible that the switch is keeping the starter running until the ECU has had time to figure out that the engine has starter and inhibit it. Or it may just be a sticky solenoid, of course! |
Does the ABS system sometimes make a noise on starting?
stricko Member Since: 30 Nov 2015 Location: East Sussex Posts: 120 ![]() ![]() |
I've noticed this on mine.
We only got the car on Friday so just getting used to all the various noises and rattles and working out which ones are normal and which ones need looking into. It feels to me like the ignition switch isn't returning back to its correct position after starting. In fact I have to move it back a bit myself. The Grrr noise sounded like the starter to me but I wasn't sure. Does anyone have a link to the TSB mentioned ? Cheers --------------------------------------------------------------- |
