![]() | Home > Puma (Tdci) > low RPMs at Idle = vibration |
kirk Member Since: 08 Dec 2012 Location: Abu Dhabi, UAE Posts: 28 ![]() ![]() ![]() |
Hi All,
Seeking your feedback/experiences... My puma idles around 800 RPM and this causes the engine to vibrate which in turn causes the vehicle to rattle vibrate. I step on the gas peddle a touch to increase RPMs to +/-1000 and the vibration stops (but its difficult to keep a constant idle speed). Is there a screw to turn up the idle or is it me that has a screw loose? cheers, Kirk |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17677 ![]() ![]() ![]() |
Idle speed is set by the ECU => no screw.
can it somehow be adjusted so the vibration stops?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20696 ![]() ![]() |
Try this instead first: http://www.opieoils.co.uk/p-60222-millers-...tment.aspx
(Or an alternative.) |
