Home > My Defender > 2002 110 "black" limited edition |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
Ray
16th Jun 2015 9:16pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
Click image to enlarge 2002 110 td5 |
13th Aug 2015 6:12pm |
Looks great!!! Ray
13th Aug 2015 6:38pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
10/10 you want to swap for a white one
getting the chequer plate off and re anodised is on my list to do, but the local one isnt getting back to me yet |
13th Aug 2015 8:28pm |
It wasn't easy to find an anodiser to do it actually. The problem seemed to be the size of the components. A large firm in Huddersfield had a minimum order of nearly £400 so that was a no go. A smaller firm said it would require a full production run unshared with any other components and therefore quoted a similar price. Eventually Colour Anidising in Manchester came up trumps. They did a great job and it really does look like new.
It was a lot of chasing around but I think we'll worth it in the end, especially as now the plates on the steps are black as well. 2002 110 td5 |
13th Aug 2015 9:16pm |
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 401 |
Lovely looking truck a credit to you
2nd Dec 2015 10:37pm |
Thanks. Appreciate the compliment 2002 110 td5
3rd Dec 2015 9:53pm |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 |
I saw earlier in your thread that you had the side runners galvanised. Presumably you drilled out the rivets to remove the tread plate and rubber packing piece?
Did you use ordinary pop rivets when refitting? Have they squashed the rubber a bit? I'm wondering about getting my new runners powder coated to hold back the rust a bit. No three year warranty for me as I bought them second hand. Cheers, Angus Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
23rd Feb 2016 11:26pm |
I fitted rivnuts instead and just tightened the bolts (countersunk Allen) until they started to compress the rubber. They were quite fiddly though due to the curved surface of the step. The original rivets were fitted with spacers to avoid crushing and distorting the aluminium.
To be honest, the only reason for doing this was to replace the silver chequer plate with black. The side steps were the originals from 2002 and had cavity wax applied. There wasn't a spot of rust on them and the powder coating had also lasted well. I had them galvanised because it was almost free to do due to the minimum weight policy my local galvanisers have (100kg if I remember correctly). 2002 110 td5 |
24th Feb 2016 5:03pm |
I have just been given this for my birthday. A friend of my brother paints them. I think it's pretty good! Now to get it framed
4th May 2016 6:34am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
It is good, your very lucky Clayton.
5th May 2016 8:15pm |
Great pic and happy birthday Ray
6th May 2016 2:06pm |
Cheers mate 2002 110 td5
6th May 2016 6:30pm |
Birthday treat. Camping on my own in the middle of the north York moors.
6th May 2016 8:43pm |
