Home > Maintenance & Modifications > Puma Pickup to Van conversion with a roll cage. Help needed. |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 717 |
This could be an option if you want to keep it as a pickup as it doesn't lose cargo space: http://www.whitbread-offroad.co.uk/roll_ca...ck_cab.php
30th Nov 2015 12:44pm |
In answer to the other question, it is possible to convert between the two fairly easily, it all just unbolts. You need a rear door, roof and sides. Few hours with a spanner, probably a helper to lift the roof on and away you go. My helper for taking my 110 roof off had a gammy arm, so I put the roof rack on and lifted the whole lot off with a telehandler.
30th Nov 2015 1:09pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
My 2003 td5 pick-up became a hard top by using 1984 and 1987 parts.
Click image to enlarge Click image to enlarge And then I put a North Offroad cage on. Click image to enlarge The hardtop might not be a 100% direct fit. I needed to drill a few holes different to get the safety belt bracket in place. The bracket changed a little between 1984 and 2003. But nothing mayor. A North Roll cage looks a little different the most cages on a 90 specially the hoop near the front seat is placed a little more backward then other modells. This is because this way you can easily make a cross behind the front seats giving the cage more support. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
30th Nov 2015 2:16pm |
Striker Member Since: 04 May 2013 Location: Yorkshire Posts: 127 |
This was on my short list, but we have decided she wants the dogs on the inside of the Landy. plus I was not sure about the cross bracing or lack of it behind the seats. Cheers Andy Never Knowingly Understood |
30th Nov 2015 4:38pm |
Do you have any more photos of the cage and the internal hoop. I got a quote from North this morning but they look well made. Thanks for the replies Cheers Andy Never Knowingly Understood |
30th Nov 2015 4:44pm |
Just to clarify, the side panels and roof from a TDI 300/TD5 will fit on a Puma with some re drilling of holes. Cheers Andy
30th Nov 2015 4:48pm |
Please note that I have a mismatch off parts. I build my 90 out off a accident write off 2003 td5 and a rotten 1984 but with good body. And to drive tax friendly I converted it to on a commercial license.
Click image to enlarge Currently I have a 1984 nose and doors, 2003 bulkead and rear tub, 2007 isch roof and sides and a rear door from unknown year. I changed parts around to as you can see where my 90 is on the trailer it still had the 1984 roof. Later I put on the Dutch tax roof. Click image to enlarge I had to drill some holes in the roof part to get the seatbelts fitted, no changes to the body off the 90. I noticed that with 19 years between my 90's only little changed body wise, like the hole for the lights got bigger and the bottom doorseals moved from the body to the doors, leaving me without seals for a while. If you buy a hard top make sure the headlining comes with it, I don't know how it is in the UK but here in The Netherlands they are bloody expensive. The North off road cage comes or welded and fitted or as a flatpack that you have to weld yourself. But it is designed as a fully welded cage. I didn't like that as I like to have everything removable so I made soem changes to the cage. Click image to enlarge As you can see I can split the cage at the middle hoop and I can take the support below the front windscreen out. Also the inner support is completely desinged by me as that wasn't included in the kit I bought. Click image to enlarge Before making any comments that this isn't strong as the cross should be connected to the chassis too, you are right but my 90 isn't a finished project (started in 2009 ) I have plans to install a second winch below the rollcage cross so I can feed the cable trough the roof or through the reardoor. The winch, that I don't have on the moment will bet fitted on the chassis crossmember just below the body there so the a additional support will be made too. But I am still thinking off other possibilities to place the rear winch so it is not definitive yet. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
1st Dec 2015 7:58am |
Roel,
I've gone down this route for the cage. Click image to enlarge I'm currently working on the roof and side panels. The rear door is on order from a local supplier Cheers Andy Never Knowingly Understood Last edited by Striker on 30th Dec 2015 7:46pm. Edited 1 time in total |
30th Dec 2015 7:43pm |
double post deleted Cheers Andy
30th Dec 2015 7:45pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8021 |
i would use North Off Road if you want a proper cage fitting in my experience, they will fit it nice and tight to the body work too.
if you want to fit your own P&P would get my vote or weld up a North one. i have a 90 Puma hardtop with internal cage (P&P one) can take some pics if you like? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
30th Dec 2015 8:30pm |
Thanks James,
Yes please, I'd like to see the photos and compare the differences. I know the one we went for is a compromise based on price and internal space. The picture shows the cage that was temporary fitted just to get it home. I've already taken it off and will fit the 6 chassis brackets when I get the pickup cab off I'll take some more photos of the clearance between the cage and bodywork when I get the hard top on. Cheers Andy Cheers Andy Never Knowingly Understood |
30th Dec 2015 9:27pm |
I forgot to say mine was from AT4x4. Cheers Andy
30th Dec 2015 9:39pm |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
I Have this cage in the back of my 90HT... Supplied by Bowler as used on the Challenge Defenders... Although I only had the rear section fitted..
Click image to enlarge Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
31st Dec 2015 1:02am |
That looks very substantial without losing out on the rear space. I like it
Can I ask the price? Pm me if you prefer. Wow, just seen your Bowler build thread. Looks fantastic Cheers Andy Never Knowingly Understood |
31st Dec 2015 7:45am |
