BigMike
![](templates/vbnew/images/spacer.gif)
leeds wrote:For 'leisure' winching you certainly do not need twin batteries. You might want twin batteries and might be able to afford them but needs and wants are different things.
If you double line you halve the load on winch and the line although double the time taken for winching. You also reduce the current draw as well.
A decent battery should cope if you keep the engine revs up. If it is going to be a long winch there is nothing wrong with winching for a couple of minutes then be stationary for a few minutes revving the engine to put charge back into battery. On a single battery what you want to avoid if you are solo vehicle is discharging your starter battery so that you can not start the engine if you stall it.
David Bowyer has some good videos on winching techniques. Worth watching.
Snatch block/pulley, gloves and tree strop are all useful.
Most useful thing is probably a bucket load of common sense. SAFETY comes first, learn safe techniques!
HTH
Brendan
hm, I dont quite agree there Brendan. If you halve the amp draw and the load, the motor has less work to do and hence it can actually move quicker than a heavy single line pull. So whilst I understand what you're saying, it's not *technically* correct. I appreciate this is being pedantic ![Laughing Laughing](images/smiles/icon_lol.gif)
7th Dec 2010 5:41pm |
leeds
BigMike wrote:leeds wrote:For 'leisure' winching you certainly do not need twin batteries. You might want twin batteries and might be able to afford them but needs and wants are different things.
Brendan
Hi Mike,
Being pedantic, I did not say you halve the amp draw but reduce the amp draw. In fact double lining does not halve the amp draw, however it does reduce it!
One of the big advantages in double lining is an improvement in safety as there is a reduced risk of the line breaking or breaking something in the winch!
Technically the motor will have the same amount of work to do but the rate of doing the work is decreased!
Ho hum pedantic hat thrown behind the sofa to gather more dust
Brendan
7th Dec 2010 6:20pm |
BigMike
touché ![Laughing Laughing](images/smiles/icon_lol.gif)
7th Dec 2010 6:31pm |
