Home > Tdi > Heater fan lever
vx490man
Wales
Heater fan lever
Heater fan control lever very stiff
Post #475690 24th Nov 2015 8:32am
dorsetsmith
Heater fan control lever very stiff i tack you meen fan speed Question
remove dash front and check for obstruction i.e. wiring cort in the slider and also check control cable shown in parts book Exclamation
or if you meen air to top or bottom check control cable i.e. no kinks in it, make shore the flap in the lower dash is free too move
Post #475698 24th Nov 2015 8:54am
vx490man
Wales
Thanks for your help I am new on the defender scene only had mine two weeks
Post #475876 24th Nov 2015 6:31pm
dorsetsmith
that no problem every day is school day and why we are here Thumbs Up
Post #475888 24th Nov 2015 6:52pm
It can be sometimes also that the cable doesn't slide back into the cable sheath and bends instead.
The Puma has these control cables so a TD5 probably has some too I expect.
They are like a bike brake cable, plastic outer braided steel wire inner.
If it isn't this it'll likely be trapped or jammed as suggested above. Thumbs Up
Post #475891 24th Nov 2015 6:56pm
vx490man
Wales
Thanks for your help , I am new on the Defender scene had mine 2 weeks
Post #475927 24th Nov 2015 9:00pm
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
I'm having exactly the same issue with my TD5. I'll post when I get it sorted out.
Post #476178 25th Nov 2015 7:59pm
vx490man
Wales
Look forward to hearing from you . Thanks for your help
Post #476189 25th Nov 2015 8:35pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Could even be as simple as the lever needs lubing ... give it a squirt of WD40 or similar through the slot first - you never know Wink Guns and Landrovers .... anything else is irrelevant.
Post #476204 25th Nov 2015 9:05pm
Mo Murphy
The cable inner binds in the outer most commonly due to a lack of lubrication. A good spray of wd40 into both ends of the cable outer and work the lever up and down gently until it starts to free off.
If the cable inner is bowing at the lever end and not moving in the outer at all then it really needs a new cable but I have got away with reversing the nipple in the holder ie. Turning it through 180° so that the bow leads into the outer rather than bowing around the end of the outer. It will be quite difficult to turn the nipple around as there will be a lot of spring in the inner, some long nosed pliers and a bucket of patience will help 😊
HTH
50 Shades of Pennine Grey
Post #476329 26th Nov 2015 11:34am
BCdefender
The latter is my current issue. When I have the time and bravery I'll give it a shot. Thanks!
Post #477554 30th Nov 2015 12:55am
