Home > Puma (Tdci) > Cubby |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
Could someone measure the internal dimensions of the cubby box and post them.
thanks Pom |
12th Jul 2010 4:32pm |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 |
21cm Deep, 24.5cm Wide, 21cm at top (front to back) but this increases at the base as the front is tapered.
12th Jul 2010 4:41pm |
thanks
12th Jul 2010 4:49pm |
Thought I'd tag onto this rather than start another thread!!!
Cubby box cheap PVC was beginning to look tired especially on the corners. On passing an automotive trim shop they wanted £95 plus VAT to cover and pad it!!! Decided to have a go myself!! Stripped old cover...no turning back now!!! Click image to enlarge Went to upholsterers £9 for offcut of decent charcoal leather and £1:50 for two bits of 10" X 10" foam 2" thick each!!! Click image to enlarge Roped in my father's partner who is a seamstress to do a bit of cutting and stitching!!! Click image to enlarge Stapled lot together!!! Click image to enlarge Nailed it back in vehicle...job jobbed for £10:50...result I'd say!!! Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
4th Dec 2010 7:59pm |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
nice bit of work , LR should have done it in the first place
4th Dec 2010 11:30pm |
Mr.Boots Member Since: 04 Feb 2010 Location: Wicklow Posts: 15 |
I would like to fit a cubby, which one will fit a puma? where can i get one?
5th Dec 2010 1:57am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4615 |
Exmoor trim. A lot cheaper than Land Rover including delivery to Ireland. Bought one myself and fitted it. £53.05 plus delivery. Check out the Exmoor Trim site. I think mine came in at less than 100 euro including delivery. 1982 88" 2.25 diesel
5th Dec 2010 10:31pm |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
i took this http://www.extreme4x4.co.uk/acatalog/CUBBY_BOXES.html for 185 euros. i am not the happiest man of the world it is stable but fingers are in serious danger if heavy cover fall. not recommended if there are children www.newfoundland.gr |
6th Dec 2010 8:23am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2623 |
Wow, awesome DIY mod, thanks for sharing |
6th Dec 2010 12:32pm |
Welcome!!!! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Dec 2010 3:33pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Does your Father's partner make to order?
Nice job One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
7th Dec 2010 12:05am |
mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143 |
got a genuine new one off ebay awhile back for £45 LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE |
16th Jul 2011 5:06pm |
