![]() | Home > Puma (Tdci) > Cubby |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
Could someone measure the internal dimensions of the cubby box and post them.
thanks Pom |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 ![]() ![]() ![]() |
21cm Deep, 24.5cm Wide, 21cm at top (front to back) but this increases at the base as the front is tapered.
thanks
Thought I'd tag onto this rather than start another thread!!!
Cubby box cheap PVC was beginning to look tired especially on the corners. On passing an automotive trim shop they wanted £95 plus VAT to cover and pad it!!! Decided to have a go myself!! Stripped old cover...no turning back now!!! ![]() Click image to enlarge Went to upholsterers £9 for offcut of decent charcoal leather and £1:50 for two bits of 10" X 10" foam 2" thick each!!! ![]() Click image to enlarge Roped in my father's partner who is a seamstress to do a bit of cutting and stitching!!! ![]() Click image to enlarge Stapled lot together!!! ![]() Click image to enlarge Nailed it back in vehicle...job jobbed for £10:50...result I'd say!!! ![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
nice bit of work
Mr.Boots Member Since: 04 Feb 2010 Location: Wicklow Posts: 15 ![]() ![]() |
I would like to fit a cubby, which one will fit a puma? where can i get one?
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4780 ![]() ![]() |
Exmoor trim. A lot cheaper than Land Rover including delivery to Ireland. Bought one myself and fitted it. £53.05 plus delivery. Check out the Exmoor Trim site. I think mine came in at less than 100 euro including delivery. 1982 88" 2.25 diesel
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
i took this http://www.extreme4x4.co.uk/acatalog/CUBBY_BOXES.html for 185 euros. i am not the happiest man of the world ![]() it is stable but fingers are in serious danger ![]() not recommended if there are children www.newfoundland.gr |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
Wow, awesome DIY mod, thanks for sharing ![]() |
Welcome!!!! ![]() Treat every day as if it is your last....one day you will be right!! |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Does your Father's partner make to order?
Nice job ![]() + New Defender 110 First Edition |
mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143 ![]() ![]() ![]() |
got a genuine new one off ebay awhile back for £45 LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE |
