Home > Td5 > Moving Defender dash instruments and bulbs
funrover
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Currently I'm building a tribute to the Land Rover and as part of it, I want to make a series style dash. I plan on moving the instrument dials to the centre of a custom dash and have old fashioned bulbs (with labels). Is it possible to reroute the current warning lights by extending the wiring to reposition them? Editor of FunRover - One blog. Read it!
Land Rover rebuild video series here:
Post #474858 21st Nov 2015 3:39pm
roel
The cables might even be long enough. Roel
2003 90 Td5 (2009-now)
Post #474864 21st Nov 2015 3:58pm
PaulMc
Re: Moving Defender dash instruments and bulbs
The TD5 warning lights use cable-mounted 16-way and 20-way 040 female connectors.
There's a cable-mounted male connector for the 20-way - but, not for the 16-way.
There are PCB male headers for 16-way and 20-way, in both vertical and horizontal mountings.
There's also a horizontal mounted 36-way PCB male header, which combines the 16-way and 20-way into a single PCB header.
The 14-way 090 connectors used on the instrument harness for speedo and gauges, can have their terminals released and replaced with new terminals with longer cables - or, have a male/female extension harness plugged-in, to go between the main harness female connector and the instrument harness male connector.
. Paul.
Post #474878 21st Nov 2015 4:42pm
funrover
Thanks Paul.
I actually wanted to split out the bulbs for the warning lamps so I could make something like an old dash, like this:
Would it just be a case of desoldering the SMDs and then extending them on wires?
Post #474896 21st Nov 2015 5:28pm
Martin
Site Admin
Why would you do that?
You could just use your own lamps and wire them into the Td5 loom using the connectors Paul has identified.
The Td5 ECU will happily drive bulbs, I had a pre-Td5 warning panel for a while with the Td5 conversion.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #474898 21st Nov 2015 5:44pm
Martin
Site Admin
Or you could use panel-mounted LEDs.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #474899 21st Nov 2015 5:46pm
funrover
Thanks chaps, I understand now, shouldn't be too difficult a job then Editor of FunRover - One blog. Read it!
Post #475779 24th Nov 2015 1:37pm
