![]() | Home > Puma (Tdci) > Boomslang loom issue |
From this thread......
http://www.defender2.net/forum/topic41092....=boomslang If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 555 ![]() ![]() ![]() |
I'm quite happy with my Boomslang loom, I would definitely recommend it. I did make a few changes though, like adding convoluted sleeve on the unprotected portions of the wire feed.
The loom is pretty simple, I reckon, only thing that can go wrong are the relays, so I would start with this. |
Shiltmeister Member Since: 06 Dec 2014 Location: Mallorca Posts: 32 ![]() ![]() ![]() |
Thanks guys. Yeah think i'll start with the relays and go from there.
Unless I imagined it, Im pretty sure the full beam worked for a few seconds when I first turned it on. Only wanted to stop replacing melting switches. 2009 Puma 110 SW |
