![]() | Home > Off Topic > Refurbishing my 200 year old cottage need advice on tiling |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
First you cannot tile on floorboards you will need to cover any floorboards with 13mm-thick exterior grade plywood fixed with countersunk screws, the other areas where you say you have 9mm ply is not thick enough for floor tiles . I have never primed the plywood as the tile adhesive that you will be using is waterproof. The dip in the floor will probably be no problem after you have laid the plywood, put place some packing under the plywood when you lay it so as not to create a bounce effect to the floor………..
So as not to type loads of advice for you one of the best guides to laying floor tiles is to be found here http://www.diy.com/help-advice/how-to-tile...100035.art For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Triggerfinger Member Since: 18 Aug 2015 Location: landyrotty Posts: 129 ![]() ![]() |
Ok thanks the dip in the floor is a problem, where the kitchen extension is a concrete floor & has a slightly different
level (I missed that part on the first post ooopps sorry) & dips I can use an extra piece of ply but the edges would need filling im not sure that using extra adhesive to make it level would work or use some sort of self levelling compound?? I had a company out a while ago to have a look they assured me the floor was sound enough with the 9mm hard wood ply?? the bathroom floor had the same and was down for 10 years with no problems. They wanted 1500 quid just for labour that's 1500 quid I could spent on my landy ![]() Thanks Kev ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20627 ![]() ![]() |
You'll need castellated trowl or spreader for the tile adhesive.
I'd tape the jobs in the ply too, think there is some that's used on plasterboard but can't think of the name. Wickes do a good range of everything you need. Depends on the size you need, but they do pre-mixed adhesives and grout or powder form to mix. Follow all instructions and you should be fine. All of the above post seems concise to me too. Agree 100% |
LEZ Member Since: 22 Oct 2015 Location: London Posts: 167 ![]() ![]() |
I usually use Bal primer for the external ply, most decent tile shops sell it.
One serious word of advice, get yourself some cushioned rubber knee pads (screwfix do some good cheap ones) they will save your knees from getting messed up like mine are from too much floor tiling. |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 ![]() ![]() ![]() |
Hi stew here , spend 99% of my time on disco 3 as that's what I drive
![]() Tiles on a wood floor , I hope your floor hasn't got a lot of spring in it ? , I'm taking it's a ground floor ? , you will need to fix a 6mm tile board on the floor first , you can get this from most builders merchants or the likes of topps tiles , then you will need to use a flexible adhesive and a flexible grout , don't use the pre mix tubs because it's not the same and doesn't work ![]() I've been in the building trade for over 30 years and we do a lot of tiling ![]() Stew |
Ta much steve I put "castellated trowl" into my browser and got Viagra ![]() ![]() |
Knee pads added to the list nice one Ta much for the tip on Bal primer ![]() |
Hi Stew the floor has no noticeable spring and is a ground floor even with my fat a$$ bouncing on it ,very solid even more so with the ply on it, I can just leave the ply down & use tile board on top since I cant return it full of holes ![]() Thanks for the tip on the pre mix ![]() |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
The recommendation for the screw spacing when fastening down the exterior or marine ply is 6" on centre, i.e. no screw is more than 6" away from the next. When I did the bathroom I made a jig out of scrap ply as it saved on all that measuring, the ply needs to be top quality so as to avoid voids in the ply. If the dip is not to bad you can level it with tile adhesive first so that the floor is level. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
I believe you only use that product if laying a hard core floor or to perk up a sagging tiled floor ![]() http://www.youtube.com/user/conwy1 |
Good idea for the jig thanks il have a very good look at the dip & measure the difference before doing anything ![]() Thanks matey ![]() |
Just what I need more hardwood ![]() ![]() |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
Ceramic tiles on a ground floor?
Porcelain surely for longevity & flexibility. Good luck! |
And as another thought, if you spread the floor with the notched trowel in straight lines, then spread the back of the tile at 90 degrees, you will get good coverage and adhesion.
Also Topps sell leveling clips, really useful and save lots of time, with about 550 tiles to lay, I bet that £1500 starts to look very reasonable at tile number 295! ![]() |
