Home > In Car Electronics > Ignition feed for dlr lights |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6628 |
Welcome to the site!
Ignition switched wires are White with a Green stripe 1988 90 Td5 NAS soft top 2015 D90 XS SW |
18th Nov 2015 11:53pm |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
Morning, I took a feed from the radio for mine.
19th Nov 2015 7:20am |
Rogeo1983 Member Since: 18 Nov 2015 Location: Horsham Posts: 30 |
Thanks lads, so just to confirm the Green and white striped cable in the loom against the bulkhead in the engine bay is ignition?
Thanks again |
19th Nov 2015 1:31pm |
Be careful - I said white with a green stripe. NOT green with a white stripe, they are different.
Green with white is right hand indicator. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
19th Nov 2015 1:33pm |
Hi martin,
Should have checked here before I wired!! Dlrs come on with right indicator!! I don't have a white wire with a green stripe. I am looking at the loom to the outside of the washer bottle. Any ideas? |
19th Nov 2015 3:44pm |
Ok, just finished the wiring. Found the white wire with a green stripe, and it works perfectly.
I spent a few extra hours doing it, just to ensure all joints were soldered properly, with heat shrink, and cable tied along other wires to protect from chaffing etc. Very impressed with the result, it looks great. Many thanks for your help, and very quick replies. ....on to the next project! |
19th Nov 2015 7:12pm |
