![]() | Home > In Car Electronics > Ignition feed for dlr lights |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
Welcome to the site!
Ignition switched wires are White with a Green stripe ![]() ![]() ![]() |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Morning, I took a feed from the radio for mine.
Rogeo1983 Member Since: 18 Nov 2015 Location: Horsham Posts: 30 ![]() ![]() |
Thanks lads, so just to confirm the Green and white striped cable in the loom against the bulkhead in the engine bay is ignition?
Thanks again |
Be careful - I said white with a green stripe. NOT green with a white stripe, they are different.
Green with white is right hand indicator. ![]() ![]() |
Hi martin,
Should have checked here before I wired!! Dlrs come on with right indicator!! I don't have a white wire with a green stripe. I am looking at the loom to the outside of the washer bottle. Any ideas? |
Ok, just finished the wiring. Found the white wire with a green stripe, and it works perfectly.
I spent a few extra hours doing it, just to ensure all joints were soldered properly, with heat shrink, and cable tied along other wires to protect from chaffing etc. Very impressed with the result, it looks great. Many thanks for your help, and very quick replies. ....on to the next project! |
