Home > In Car Electronics > Cb aeriel help please
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all, struggling to get the SWT reading outa the red on a new installation,
I reckon it's earth related ? But I have added a separate earth lead direct to a good ground, and still doesn't affect the reading,
The lowest reading I have Is 10 which is way into the red and can damage the cb itself is used
I have added a couple of pics below, since these were taken I have ground down more bare metal around the earthing plate
I have tried two different leads and connectors also
Any tips please guys Sad
P.s I am aware it won't be perfect inside the workshop, but I threw a mag mount on the bonnett with the same aeriel and it samosa perfect, just a very slight movement of the needle
Post #473966 18th Nov 2015 6:16pm
Laurie
It's probably your positioning. You're generating a poor ground plane.
Try using a centre loaded aerial.
Post #473969 18th Nov 2015 6:23pm
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Mine is the same but thanks for the tip on the mag mount. I am fed up of pulling back the trim and filing away at the metal to get a good earth to no avail!
Post #473974 18th Nov 2015 6:41pm
Daisy90
Hi Laurie,
As it happens I have a dome mount with a 90 degree thingy on it,
Still the same reading ,
If it's just positioning, I'm gutted as all the work I have done it's the only hole I have drilled in a brand new truck Crying or Very sad
Post #473975 18th Nov 2015 6:49pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Your aerial positioning isn't too bad, but ideally the spring portion should be above roof level.
Have you got good good earth at BOTH end of the cable - the CB unit needs to be well earthed and make sure there are no short circuits between the earth & signal wire.
On my setup I had a real problem getting a good SWR, in the end I replaced the aerial, mount & wire, despite having checked them all during installation I couldn't find exactly where the problem was. However, after changing the parts, it worked just fine. I suspect the cable had an internal bad connection.
Might be worth running some new cable and re-doing the connectors at both ends.
cheers
simon
Post #473983 18th Nov 2015 6:57pm
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
Ditto on the aerial position needs to be higher so the spring clears the body work. Try adding a quick release mount to the base and aerial to add a bit of height. Adventure isn't paved!
Post #478480 2nd Dec 2015 8:06pm
Panda
England 2015 Defender 110 Puma 2.2 XS CSW Fuji White
Hi
Check the screening/braiding on the coax, its either broken or has come adrift. The antenna to the transceiver is out of balance. You need to cure this before tuning in the antenna and reducing the SWR
cheers Monty-2015 2.2 110 XS Puma Station Wagon
Yoda Disco 3-Sold
Larry Disco 1-Sold
Muddly XS 90 TDCI-Sold
Pearl Disco 2-Sold
Larry Disco 1-didn't want too but sold
Post #478490 2nd Dec 2015 8:33pm
