Home > In Car Electronics > Cb aeriel help please |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
It's probably your positioning. You're generating a poor ground plane.
Try using a centre loaded aerial. |
18th Nov 2015 6:23pm |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 |
Mine is the same but thanks for the tip on the mag mount. I am fed up of pulling back the trim and filing away at the metal to get a good earth to no avail!
18th Nov 2015 6:41pm |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 |
Hi Laurie,
As it happens I have a dome mount with a 90 degree thingy on it, Still the same reading , If it's just positioning, I'm gutted as all the work I have done it's the only hole I have drilled in a brand new truck |
18th Nov 2015 6:49pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Your aerial positioning isn't too bad, but ideally the spring portion should be above roof level.
Have you got good good earth at BOTH end of the cable - the CB unit needs to be well earthed and make sure there are no short circuits between the earth & signal wire. On my setup I had a real problem getting a good SWR, in the end I replaced the aerial, mount & wire, despite having checked them all during installation I couldn't find exactly where the problem was. However, after changing the parts, it worked just fine. I suspect the cable had an internal bad connection. Might be worth running some new cable and re-doing the connectors at both ends. cheers simon |
18th Nov 2015 6:57pm |
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 |
Ditto on the aerial position needs to be higher so the spring clears the body work. Try adding a quick release mount to the base and aerial to add a bit of height. Adventure isn't paved!
2nd Dec 2015 8:06pm |
Panda Member Since: 29 May 2015 Location: Essex Posts: 432 |
Hi
Check the screening/braiding on the coax, its either broken or has come adrift. The antenna to the transceiver is out of balance. You need to cure this before tuning in the antenna and reducing the SWR cheers Monty-2015 2.2 110 XS Puma Station Wagon Yoda Disco 3-Sold Larry Disco 1-Sold Muddly XS 90 TDCI-Sold Pearl Disco 2-Sold Larry Disco 1-didn't want too but sold |
2nd Dec 2015 8:33pm |
