Home > Maintenance & Modifications > Cutting a slot in the fuse box cover
Dave Bellis
United Kingdom 2014 Defender 90 Puma 2.2 HT Keswick Green
What is the best way to cut a neat slot in the plastic fuse box cover about 25x45mm to mount a blue tooth OBD adaptor?
Dave
Post #471669 11th Nov 2015 5:36pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Hi Dave,
Have you thought of something like this so you don't have to cut anything http://www.amazon.co.uk/gp/product/B00XHFM...ge_o05_s00
Steve
Post #471681 11th Nov 2015 6:15pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Make a template by drawing the shape of the opening on paper. Cut out and glue it to the outside of the lid, checking the position is right. Drill a number of small holes adjacent to one another about 5mm inside the final opening. Cut between the hole with a carpet knife to remove the core. File out the rest with a round file.
Patience and a steady hand. Half an hours work.
...or buy the adapter HS has suggested - good idea.
Stephen 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #471683 11th Nov 2015 6:23pm
Dave Bellis
Steve,
thanks for the reply, yes I've tried a low profile connector but it still fouls the cover. I came to the conclusion that a slot cut in the fuse box cover maybe best unless someone has a better idea...
Dave
Post #471688 11th Nov 2015 6:27pm
Why not just pop the OBD port out of its holder
Post #471691 11th Nov 2015 6:30pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
^^^^^exactly that^^^^^^^ 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #471694 11th Nov 2015 6:35pm
TJ101
Then put a splitter cable in That how i run mine, and can then still access the OBD port
http://www.amazon.co.uk/Splitter-Extension...d+splitter California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #471737 11th Nov 2015 7:58pm
Stacey007
I cut mine with a Stanley knife
Easy enough job, looks neat (no one will see it) Its almost out of site. The way I looked at it I could get a fuse cover from a breakers for a few quid If needed to put back?
Works well, still not set up the guage properly but I like the digital speedo, revs, etc
What figures have people put into for the MPG part to work out correctly on a 110 ?
Post #471746 11th Nov 2015 8:24pm
PK1
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I did the following if it helps:-
1. Pop the original connector out
2. Connect it to a Y cable
3. The other end to your OBDII accessory and place up behind dash
4. Pop the remaining connector back in the original slot
No need to cut a slot Thumbs Up Defender 110 TDCi XS SW
Range Rover Sport HSE
Post #471749 11th Nov 2015 8:32pm
landy andy
I just removed the small retaining surround for the plug, then plugged in my scangauge, then poked both through the hole. No cutting, not permanent, easy.
Post #471824 11th Nov 2015 10:50pm
