Home > Wheels & Tyres > Wheel/tyre fit - advice please
Davidej
United Kingdom 1996 Defender 110 300 Tdi SW Alveston Red
Expect this has been covered before but a regular forum member has offered me some 8.5J wolf wheels for my 255/85/16 BFGs. Would welcome comments on whether this is a sensible fit as most wolfs seem to be 6.5J. I also have 30mm spacers on the hubs.
Post #470949 9th Nov 2015 1:01pm
jimbob7
Have you questioned the size,Wolfs only come in 6.5?? Pov.spec,ftw. 2006, 110,TD5.
Post #470963 9th Nov 2015 1:37pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
GEN Wolfs are only 6.5 However would not be surprised if copys come in larger sizes or hes getting confused with Modulars.
Post #470967 9th Nov 2015 1:48pm
Davidej
Thx guys have seen pics and stamp does seem to be 8.5. The member is well known on this site so not doubting him. Just checking to see what is advised rim size for these tyres on a wolf wheel or any other recommended steel. assume then that the 6.5 would be ok for 255/85/16s. Are there different offsets I need to be aware of?
Post #471041 9th Nov 2015 6:16pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
As Dave18 says, genuine LR Wolf wheels only come in 6.5J width flavour. There are plenty of other numbers stamped on the rim though so best check width with a tape measure. If its not 6.5J, its not a Wolf rim.
As for fitting 255/85R16's to Genuine LR Wolfs, that is fine, although 6.5J is the narrowest rim they can be fitted on (FYI, widest is 8J).
The offset on the Wolf is ~20mm. A Boost alloy wheel is about 33mm. Therefore the Wolf sits ~13mm further outboard than the Boost which is what you want to be able to gain more steering lock. Spacers would push them out the additional 30mm for even better lock, but would start to bring in negatives such as general muck constantly being thrown up the sides of the car, and possible steering shimmy.
255/85R16's on Wolf wheels is possibly the best wheel/tyre combo possible on Defenders I reckon. (without spacers for me) Wink
Post #471324 10th Nov 2015 3:09pm
Davidej
Thanks Andy really helpful. Will double check with member to ensure these are genuine wolfs
Post #471338 10th Nov 2015 4:33pm
