Home > Wheels & Tyres > Wheel/tyre fit - advice please |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Have you questioned the size,Wolfs only come in 6.5?? Pov.spec,ftw. 2006, 110,TD5.
9th Nov 2015 1:37pm |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 |
GEN Wolfs are only 6.5 However would not be surprised if copys come in larger sizes or hes getting confused with Modulars.
9th Nov 2015 1:48pm |
Davidej Member Since: 30 Sep 2014 Location: Devon Posts: 266 |
Thx guys have seen pics and stamp does seem to be 8.5. The member is well known on this site so not doubting him. Just checking to see what is advised rim size for these tyres on a wolf wheel or any other recommended steel. assume then that the 6.5 would be ok for 255/85/16s. Are there different offsets I need to be aware of?
9th Nov 2015 6:16pm |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 717 |
As Dave18 says, genuine LR Wolf wheels only come in 6.5J width flavour. There are plenty of other numbers stamped on the rim though so best check width with a tape measure. If its not 6.5J, its not a Wolf rim.
As for fitting 255/85R16's to Genuine LR Wolfs, that is fine, although 6.5J is the narrowest rim they can be fitted on (FYI, widest is 8J). The offset on the Wolf is ~20mm. A Boost alloy wheel is about 33mm. Therefore the Wolf sits ~13mm further outboard than the Boost which is what you want to be able to gain more steering lock. Spacers would push them out the additional 30mm for even better lock, but would start to bring in negatives such as general muck constantly being thrown up the sides of the car, and possible steering shimmy. 255/85R16's on Wolf wheels is possibly the best wheel/tyre combo possible on Defenders I reckon. (without spacers for me) |
10th Nov 2015 3:09pm |
Thanks Andy really helpful. Will double check with member to ensure these are genuine wolfs
10th Nov 2015 4:33pm |
