Home > Tdi > Top gear engine speed 300TDI
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
Hi
I own a 2012 TDCI Land Rover Defender which as you will all know is geared to run quite easily at motorway speeds in a fairly refined manor for a Defender.
My son has recently purchased a 300 TDI Defender which seems to be quite low geared.
Does any body know what the final drive gearing speed against rpm is the engine sound quite busy even at an indicated 50mph.
Is the TD5 model geared the same as a 300TDI.
Thanks for any help you can give me.
Post #470921 9th Nov 2015 11:45am
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
can't give you a definet answer.. but you could possibly check one thing? not sure if it will tell you much.
I believe all (if not most cars) the gear before top gear is always 1:1 with the engine. So, if a 5 speed manual, 4th gear will be 1:1.
you'll see this when you change into 4th and accelerate the rev counter and speedo will go up at exactly the same rate, i.e the needles will move around the counter at exactly the same time.
This is assuming you have a rev counter Thumbs Up
Not sure if this will help, but should show you if the gearbox fitted is the correct ratio?
Good Luck!
Browny My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #470932 9th Nov 2015 12:55pm
MJN110
The 300TDI does not have a RPM counter these were not introduced until the Puma models were introduced.
What I am looking for is MPH per 1000rpm.
Thanks
Post #471319 10th Nov 2015 3:58pm
gilarion
Can’t help with a 300Tdi but on a 200Tdi I achieve this on a flat road
Defender 90 county
1000 rpm up to twenty mph up to third gear
2000 rpm 30- 40 mph fourth gear
3000 rpm 50-60 mph fifth gear
3500 rpm 70 mph fifth gear
I rarely go faster than 70 mph but at times I do touch 80 when ovetaking and the rev counter tends to just creep over 3500.
The only engine mod I have on the 200Tdi is a Ali Sport intercooler. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #471331 10th Nov 2015 5:03pm
MJN110
Hi
I believe your 200TDI has a different gearbox the 300TDI has a R380 type.
The engine sounds as if it is running at quite high RPM even at 50MPH and before anybody suggests it we are not in low box!
Thanks
Post #471485 11th Nov 2015 6:28am
Toby60
United Kingdom 2002 Defender 90 Td5 HT Coniston Green
Sounds normal to me. You could check the ratio of the transfer box which should be shown on a label located underneath the level plug. Also the serial number of the transfer box is adjacent to this and this will tell you (from a look up table on Ashcrofts web site)
The standard ratio I believe is 1.4 (on a TD5 anyway) which feels low geared, as at 50mph you are looking for another gear. I also believe some Defenders had a 1.6 ratio transfer box which would defenatly give high revs at 50mph. Recently I had a Discovery transfer box 1.2 ratio fitted which is a great improvement and drives well at higher speeds. ------------------------------------------------
2002 TD5 90 HT County
Post #471488 11th Nov 2015 7:10am
LR90XS2011
If you go on Ashcroft's website it gives all the info you need and all the options for improving, bigger wheels being the easiest DEFENDER 90 TDCI XS,
Post #471490 11th Nov 2015 7:21am
Browny90
Is the clutch slipping>>?? My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #471609 11th Nov 2015 3:37pm
sako243
IIRC 5th is 0.77 as standard with a 1.4 transfer (converted mine to 1.2 and makes cruising more pleasant but towing a 2.7 tonne 3.6TDV8 L322 interesting).
The diffs are 3.54 as well.
If I've got my calculations right a 31" tyre (265/75R16 for example) will be doing just under 2900RPM whereas a 1.2 transfer box puts it to just under 2500RPM.
Post #471818 11th Nov 2015 11:41pm
MJN110
Thank you all for your advice , I will check out the ashcroft site for information.
Post #472139 13th Nov 2015 6:44am
