Home > Puma (Tdci) > oil query
rossy
oil query
hi again !
I'm still sitting on the fence regarding the 08 110 mentioned in an earlier post but the money is starting to burn a hole in my pocket
On the service history the gap between 1st and 2nd services was between 10 - 11k but between the 2nd and the last one the previous owner waited for 14k miles. I think thats too much especially as I,m trading in an immaculate Mitsubishi outlander where I have changed oil + filter 6 times in 30k miles due to mostly short journey work and a 4ltr sump.
The LR dealer that serviced it only ever used SLX (fully synth trade version of edge ) and I'm aware that LR recommend a semi synth such as magnatec. Although 1) the puma has a 7 ltr sump 2) the car was mostly driven longish distances 3) there's no blue smoke cold or warm I'm concerned that something eg turbo bearings, valve train etc may have taken a hammering.
Sorry this post has turned out a bit long winded but I plan to keep the car for many years.
Does anyone know if this 'extended' oil change is OK or should I walk away ?
After all there must be many a thrashed neglected white Transit out there that's running fine and I'm sure Ford would have factored this in when it designing the Puma range of engines
cheers
Post #47042 2nd Dec 2010 10:24am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I should think you'll be fine.
14k isn't too long really with modern oils. If they've done mostly long journeys you should have no issues. I wouldn't worry about the oil change interval at 14k. The factory recommends 12k but 14k in a year is OK. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #47180 2nd Dec 2010 10:30pm
MK
If it still has the old oil, go for an oil analysis. Itīll tell you everything Puma 110" SW
Post #47189 3rd Dec 2010 12:03am
rossy
thanks guys I guess you've told me what I really wanted to hear. As I've said I'll be having a more thorough test drive next Friday after which if I go for it all I'll need (from what I've seen in this forum) is a tube of silicone, a box of spanners and a big bag of swear words to keep it on the straight and narrow ! cheers
Post #47334 3rd Dec 2010 8:39pm
mse
I wouldnt worry about an extra 2k
Obviously try an negotiate something for it...but there isnt much of an issue there. Mike
Post #47381 4th Dec 2010 9:09am
jst
it wouldnt bother me, 2k extra shouldnt be a problem if quality oil has been used. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #47387 4th Dec 2010 9:49am
