Home > Puma (Tdci) > VIN for 90 SW (HD or standard ?? )
Page 2 of 3 <123>
It might also apply to the brakes on 90s
"Vented front brake discs are fitted as standard on 110/130 models, while 90 models have solid discs. However, on 90 models with a heavy duty chassis, vented front discs may also be fitted."
- Defender MY12 Workshop Manual
Post #468820 2nd Nov 2015 9:17pm
thor44
2014 Defender 90 Puma 2.2 SW Indus Silver
Referring to topix, my 90 has the following extras, so Supacat might actually be right with the the ventilated brakes:
- VENTILATED DISC BRAKES
- HVY DUTY SUSP (L316 USE ONLY)
- T/TOW HTH-D/PLATE/BALL 7P
Post #469294 4th Nov 2015 10:13am
alby
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
Thanks Supacat
Have just checked mine while it was having its weekly wash. Mine definitely has vented discs at the front. It came from the factory with a towing drop plate and hitch too. Ive checked the colours of the springs and they correspond to it having HD rear springs (white, green, pink). My VIN plate is stamped at 2505kg.
Cool, I'm a heavy duty kind of chap with a heavy duty LDW defender, instant bragging rights down the pub Whistle Bow down Laughing
Post #469363 4th Nov 2015 2:11pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Interesting progress.
I will check front discs when I get chance.
Mine didn't have factory fitted tow option though.
And so far no one has posted with a recent 90SW that isn't HD.
BTW is there an option for private individuals to register with Topix. When I looked before it seemed to only allow registered businesses?
Post #469464 4th Nov 2015 6:37pm
thor44
You can simply register yourself as an independent operator. Thumbs Up
Post #469472 4th Nov 2015 6:48pm
thor44
I can confirm all identified differences on mine which has been fitted with a towbar from factory.
Post #469484 4th Nov 2015 7:03pm
apt100
I've also got:
JACK-HEAVY DUTY
as already discussed no factory tow option.
Also intrigued to see:
LESS MUDFLAPS-REAR
when I thought these were standard on all SW (I certainly have them fitted).
Post #469526 4th Nov 2015 8:43pm
thor44
There are several quite strange entries, but as long as they have fitted all important parts I don't really mind Very Happy
LESS BULK HEAD
LESS HOOD
LESS MUDFLAPS-REAR
Post #469627 5th Nov 2015 7:15am
Thinking that any extra heavy duty modifications for a 90 should have different part numbers, I just had a look through the Parts Manual I have (MY07) and there's these items for a 90:
Stiffener - Chassis Frame, RH, with heavy duty rear springs - KVW100590
Stiffener - Chassis Frame, LH, with heavy duty rear springs - KVW100580
Shown as item 40 on this drawing:
Not sure what this part is supposed to do - it looks like it sits on top of the body mounts?
If you wanted to buy them separately they would cost £86.88 each.
https://www.lrdirect.com/KVW100590-Reinforcement-Member/
I can't see any other parts that make a 90 chassis stronger.
Post #470360 7th Nov 2015 11:25am
apt100
Thanks for the info. Might try and have a peek underneath later Thumbs Up
Post #470385 7th Nov 2015 1:06pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
@Thor44: now on this frequency Wink thx for pointing me to this thread.
So, here I am. When I received my current 90 (2.4) in 2011, ordered new as standard continental S 90 SW, my mechanic, who was working on Wolfs in military services, pulled me on the side and whispered to be quiet, because "they send you a military HD version". Yes, it is a SALLDW and VIN check says HVY DUTY SUSP & JACK-HEAVY DUTY as well. Does anybody know what LESS HOOD means and wether LESS FRONT TOWING PIN is normal for a 90?
I never really launched intelligence to find out what military HD means, but was aware of the following: Heavy Duty springs and Wolf rims.Unconfirmed rumor is, the chassis for the military HD version is made from slightly thicker material. Could somebody provide materials strength of the chassis bars for a definitely non-HD chassis? I would be interested to compare and validate that rumor.
Never cared for other details, but after reading this thread I checked and, tata, surprise, yes I do have vented front brakes as well. Could not get to the mysterious No 40 position yet, but have a look in the future. I never thought there are more of these beasties on the road, so am keen on learning more about it.
*update* Just crawled under the Beast and had a look for No 40. Yes, there is that part fitted and also a cabin support bar running left to right attached to it. To me it looks as if load of the heavy duty springs is also supported by that additional bar, but I would need comparing pictures from non-HD to get a further idea. There is also a cable duct thingy not in the parts manual, running from where my old 109 had a NATO generator fitted to the back of the car - *wild speculation* was this car meant to be a Radio Ops Mil version? *even wilder speculation* I know there was once a large batch of sand painted very basic Mil-109s originally meant for the Algerie forces (my uncle bought one), so was there a similar TD4 batch recently as well?
*update2* These No 40 parts hold a separate stiffening bar for the frame. I crawled under a MY16 today and it is definitely a non-HD without these parts and without the vented brakes as well, so, I guess No, they are not all the same now. Never forget: cars have owner, Landrover have field service personnel.
Post #470596 8th Nov 2015 8:01am
apt100
I've also got LESS HOOD and LESS FRONT TOWING PIN.
It sounds like you have a particularly interesting version there.
I don't think mine is anything like "interesting" (no Wolf wheels etc) just an ordinary 90SW in XS trim.
My own *speculation* is that all recent 90SW are in HD spec. HD is the new Black Laughing
Post #470646 8th Nov 2015 11:25am
thor44
NinetyTD4 wrote:
@Thor44: not on this frequency Wink thx for pointing me to this thread.
Hi Ninety TD4, nice to see that you have made it to this thread Thumbs Up
Interesting information you're posting here...I'll have to crawl under mine as well to find the extra stiffening bar. And finally life-signs from a non-HD 90. Now we can start bragging about how extra heavy duty our little beasties are Whistle Very Happy
Post #470837 8th Nov 2015 9:33pm
apt100
Interesting. Was the MY16 a 90SW?
Post #470855 8th Nov 2015 10:59pm
NinetyTD4
Yes. Never forget: cars have owner, Landrover have field service personnel.
Post #470878 9th Nov 2015 7:00am
Page 2 of 3 <123>
