![]() | Home > Technical > Heated Seat upgrade |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Going back to an early question about them being noticable.
Yes they are and they are in the summer too. A few weeks back during that 5 minute hot spell we had. I was driving along and reached down to turn the A/C switch on. Less than 5 minutes later not only did I think that the A/C wasn't working, but my ass was a bit hot............I think you can work out what I did. I must look at the switch next time...... Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Ditto
![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
koltonstanley Member Since: 06 Nov 2015 Location: new jersey Posts: 29 ![]() ![]() ![]() |
sorry to bring up an old thread again but just looking for a few suggestions......
I found this kit online for heated seat wiring...comes with dash switch, and connector and wire.... Can anyone suggest a seat heater that will work with the genuine dash switch? it seams the EXMOOR kit will not work because it has a HI low setting.......so does anyone know of a kit that will work? thank you! http://www.ebay.co.uk/itm/371395023501 |
Nobody?
I know it's probably a dumb question for you guys but being in the USA with a defender is like being in the dark ages..... Any help is very much appreciated. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6327 ![]() ![]() ![]() |
Mal, going back to you first post on this subject don't you mean 1 Amp not 10 Amps?
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2321 ![]() ![]() ![]() |
Just use one of the settings and switch that with the genuine switch. If you want plug and play all genuine, then you'll have to get genuine pads.
can i buy just genuine pads?
i see options to buy entire seats with heated option....but i can seem to find just heat pads...... thanks for the replies guys..... |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
fitted some XS seats today, fitted the loom to the vehicle and went to wire it up and guess what. the upright part of the seat doesnt have the loom or heated bits in it! the base does complete with plug to go into the upright loom! i didn't think you could get XS seats unheated?
anyway i have ordered a Waeco pad set to fit in it. i should of checked before! other seat had all the right bits On that subject - heated rear 110 seats as in 2nd row - anyone done it? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20745 ![]() ![]() |
James - That's strange.
I can't see why you couldn't do the rear seats. I managed to do my front seats, with out even removing the hog rings. You do have to be careful and it's a tight fit though but not too bad at all. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Are the heat pads easily replaced on the back rest mine doesn't much but the new seat base is great
i fitted the waeco pads to some puma Vinyls on another truck and they work a treat bottom and back. so intend to do the same to this front XS one missing the elements.
Yes strange indeed, anyone else come across the non heated XS puma seats? On another note, the connectors for the looms, i will need two female fittings, went through the older posts here but the links have expired (the ones i tried) MQF are they called or simialar? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Tyco MQS i believe from Pauls post
but which ones, ideally a link of where i can buy the two wires ones from please? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Mick - Yes, not a bad job at all but best to remove the whole seat and do the job indoors or on a bench.
No tools needed. There are pics on here I think I have put up a while ago, if you can't find any I do have some pics. May give you a better idea as to how it all comes apart. James - Yes, something like that. I have them myself, PaulMC here has them and can sell you them inc OE wire tails to fit for a factory finish. Around £15 I think. I'd drop him a 'PM'. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
cheers, i have some wiring from Paul a while back, but hes not come back to me on last PM about it so guessed he had moved on. Cheers
