![]() | Home > Technical > Heated rear screen element repair kit ? |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 ![]() ![]() ![]() |
Ive just changed mine for that very reason.
Tried the repair "paint" with limited success. Paid £50 for a new window and £10 to have a friendly fitter swap it round. Recommend paying the few £ extra for a genuine part. Its scary how easy it is to push the window out! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20751 ![]() ![]() |
I'd just go for new glass as mentioned above.
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Halfords do such a kit to repair heated windows
Not cheap, and can be a bit hit and miss. I did use it on my rear window, if it stops working again I will simply replace the glass next time. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
The fixit kits I've seen look a bit rubbish IMHO, you paint it on or something like that, seems a bit Halfords 1982 to me!
Have you thought about buying a replacement rear glass? Funnily enough I am removing my tinted heated rear window next week (fully working) and will have it for sale soon. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 252 ![]() ![]() ![]() |
i used that paint on stuff on the mini.. did not work for me, the breaks were around 1 inch long.. to long for the product to conduct. 1953 80"
1987 mini city e 2011 90" |
From an old thread...
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
I fixed a break the screen trace on Dad's 110 high level brake light by soldering a bridge wire across it.
