Home > Technical > Heated rear screen element repair kit ?
Telshe
England 2004 Defender 90 Td5 XS CSW Cairns Blue
I have some parts of my rear heated screen elements broken. Are the repair kits available any good or is better to change the glass and be done with it. Your comments most welcome
Telshe
Post #469975 6th Nov 2015 9:24am
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
Ive just changed mine for that very reason.
Tried the repair "paint" with limited success.
Paid £50 for a new window and £10 to have a friendly fitter swap it round.
Recommend paying the few £ extra for a genuine part.
Its scary how easy it is to push the window out!
Post #469992 6th Nov 2015 10:19am
I'd just go for new glass as mentioned above.
Post #469993 6th Nov 2015 10:22am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Halfords do such a kit to repair heated windows
Not cheap, and can be a bit hit and miss.
I did use it on my rear window, if it stops working again I will simply replace the glass next time. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #469994 6th Nov 2015 10:24am
RRUK
The fixit kits I've seen look a bit rubbish IMHO, you paint it on or something like that, seems a bit Halfords 1982 to me!
Have you thought about buying a replacement rear glass?
Funnily enough I am removing my tinted heated rear window next week (fully working) and will have it for sale soon. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #469998 6th Nov 2015 10:33am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
i used that paint on stuff on the mini.. did not work for me, the breaks were around 1 inch long.. to long for the product to conduct. 1953 80"
1987 mini city e
2011 90"
Post #470439 7th Nov 2015 6:56pm
K9F
From an old thread...
K9F wrote:
Top two bars on mine weren't working either, bug bear was that because I've had mine tinted Land Rover were reluctant to swap it out under warranty. Had they agreed I would stll have had to pay to get it retinted. Couldn't be bothered to argue the to55 on this one! Halfords do a silver-based contact paint 'Granville' it's called comes in a tiny bottle with a masking template and a small sponge. £12 though! Sorted mine out and I affixed some transluscent 'sticky fixers' to the stoplight rubber to move it away from the heater element so it shouldn't reoccur.
Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #470448 7th Nov 2015 7:28pm
Martin
Site Admin
I fixed a break the screen trace on Dad's 110 high level brake light by soldering a bridge wire across it.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #470497 7th Nov 2015 9:49pm
