Home > In Car Electronics > ICE Upgrade - Alpine IDE178BT, Focal Speakers and Focal Sub |
Just an observation with certain speakers such as the Focal ISN 100s and for example the Alpine SPG10C2 they contain their own tweeters and the recommendation is to disconnect any other tweeters to avoid damage.
I am no expert but that was certainly the case with the Alpines. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
2nd Nov 2015 3:21pm |
jonnyboy Member Since: 15 Oct 2014 Location: Wiltshire Posts: 161 |
The ISN 100s come with the separate tweeters and a crossover cable to install behind the dash which I think does the job.
I'm no expert either |
2nd Nov 2015 3:31pm |
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 133 |
Great system
I've been dithering about upgrading my 2012 Puma as sound is fairly tinny. Good idea putting the sub under the seat rather than on back of cubby (would get kicked to pieces by kids). How was the installation - did the head unit go straight in (I've got the LR branded CD/Radio)? How much hassle is it fitting the sub (any drilling of holes/faff with cables etc? 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
2nd Nov 2015 3:59pm |
The head unit is great (I have the cd version cde178bt) Bluetooth is also good and phone calls can be heard clearly. I might have to get a couple of those subs as I like my music bassy but I'm going a different direction with the front speakers. Your setup looks great. Ray
2nd Nov 2015 4:53pm |
DG,
Fairly simple install - it had to be for me.... Head unit was a clean swap. Made a couple of extraction tools from coat hangers to get the LR one out, cabling behind was pretty much plug and play to the new unit. Mic for the phone is fixed to the top of the A pillar trim, cable run along the base of the windscreen out of sight Speakers used all existing cables Sub is fixed to the floor with self-tappers (its too big for the back of the cubby). The front edge overhangs the floor a couple of inches so got some simple 2" brackets from B&Q to fix that. Cable is then run to the head unit under mats and carpets. |
2nd Nov 2015 5:05pm |
Thanks jonnyboy
I can feel the credit card taking a hit here... 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
2nd Nov 2015 5:41pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
jonnyboy, you've installed the front speakers incorrectly.
The speakers sit behind the dash with the grilles in front of the dash |
2nd Nov 2015 5:50pm |
Like I said, I'm no expert
Thanks for that. That makes absolute sense.... |
2nd Nov 2015 5:57pm |
jackg Member Since: 22 Jun 2015 Location: west sussex Posts: 24 |
Hi Johnnyboy
Can I ask where you bought it all from? ta Jx |
3rd Nov 2015 11:41am |
Hi Jack
The focal speakers and head unit came from Car Audio Centre online. The Sub was off a shop on Ebay as Car Audio Centre didn't do them. Brodit brackets off Amazon John |
5th Nov 2015 6:24pm |
Vmesch Member Since: 06 Dec 2014 Location: Antwerp - Lier Posts: 47 |
I've just bought a Focal Sub as yours and I'm planning to install it myself. I was looking for the best way to get the 12V supply to the unit... Where did you take the 12V from? If it's including some cutting of existing wiring, how did you fix it? puma 2.2 MY2013 [:O]===[O:] |
14th Nov 2015 9:35am |
Vmesch
12V supply was straight from the battery. The supplied cable had a terminated end that fit straight to the +ve connection on the battery. Didn't trim the wire, left it coiled loosely under the cubby as I refitted it. Routing was then under the carpet/mats to the sub. -ve fixed straight to a chair bolt This is all temporary pending second battery install that I'll get round to one day... John |
15th Nov 2015 7:58am |
Hi John,
That means that it permanently stays on the 12v battery supply... The blue/white cable has to be connected then to turn the unit off when the radio is turned off, I guess? No fears that it will drain your battery? puma 2.2 MY2013 [:O]===[O:] |
15th Nov 2015 5:00pm |
There's a blue lead as well that's the remote. That., I think, together with the auto-off setting seams to switch it with the radio.
Honestly cant remember it being too difficult so must of being pretty clear in the manual for me to get right |
16th Nov 2015 9:44am |
