![]() | Home > Maintenance & Modifications > KBX grill and Led Bar |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2942 ![]() ![]() |
it will def need some custom brackets for a nice job, i am going to mount a lzser ST-8 this week end but i have the soft A bar so i hope i can mount on to this.. I have the KBX grille and like you dont want to mount through it. Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
You'll probably have to fabricate a bracket of of some C-Section steel or ally. The back of the section could be behind the grill, attachesd to metalwork under the bonnet. The from of the C section would be the only bit in front of the grille, with the lightbar brackets srcewed to it. Cut away any excess metal to make it a bit less cumbersome and you're sorted. ight be a bit fiddly to fit, but c'est la vie...
Failing that, mount from the top of the bonnet, like the Soft A-bar top mount does. pretty much screws onto the flat where the bonnet pin engages. Or mount from the bottom, from your chassis leg(s) |
p_jeeeee Member Since: 08 Jan 2012 Location: Flanders Posts: 75 ![]() ![]() ![]() |
can i mount a soft a-bar on my bumper? it's a mantec
or has someone modified the a-bar to fit this kind of bumper? |
easy job....
even if you have to cut a bit more of the A bar back you can make a really neat job of it. ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
I bought the KBX grill
Light guards are going to be powder coated and I am looking for a soft a-bar. what do you think of the set-up? ![]() Click image to enlarge ![]() Click image to enlarge |
