Home > Maintenance & Modifications > KBX grill and Led Bar
p_jeeeee
Belgium 2007 Defender 90 Puma 2.4 SV 90 Caprice
Hi guys
I am planning to buy a KBX grill for my land rover defender TD4.
But I just want to know how i can mount my Led bar onto it? I don't want to cut in the grill because it was prety expensive.
this is how i mounted it now
How do you guys fit your led bar?
Post #469298 4th Nov 2015 10:22am
mcma1
it will def need some custom brackets for a nice job, i am going to mount a lzser ST-8 this week end but i have the soft A bar so i hope i can mount on to this.. I have the KBX grille and like you dont want to mount through it. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #469321 4th Nov 2015 11:46am
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
You'll probably have to fabricate a bracket of of some C-Section steel or ally. The back of the section could be behind the grill, attachesd to metalwork under the bonnet. The from of the C section would be the only bit in front of the grille, with the lightbar brackets srcewed to it. Cut away any excess metal to make it a bit less cumbersome and you're sorted. ight be a bit fiddly to fit, but c'est la vie...
Failing that, mount from the top of the bonnet, like the Soft A-bar top mount does. pretty much screws onto the flat where the bonnet pin engages.
Or mount from the bottom, from your chassis leg(s)
Post #469333 4th Nov 2015 12:15pm
p_jeeeee
can i mount a soft a-bar on my bumper? it's a mantec
or has someone modified the a-bar to fit this kind of bumper?
Post #469441 4th Nov 2015 5:43pm
mcma1
easy job....
even if you have to cut a bit more of the A bar back you can make a really neat job of it.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Corris 110 SW
LS3 V8 build...
Post #469445 4th Nov 2015 5:46pm
p_jeeeee
I bought the KBX grill
Light guards are going to be powder coated and I am looking for a soft a-bar.
what do you think of the set-up?
Post #479568 6th Dec 2015 10:13am
