![]() | Home > Wheels & Tyres > Spare Wheel Security Chain |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
A flexible, plastic covered, heavy duty, hardened steel wire cable, or fabric covered link chain, as used for motorcycle security, would be better at protecting your spare whilst adding a layer of security/deterrent to it...
![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
Panda Member Since: 29 May 2015 Location: Essex Posts: 432 ![]() ![]() ![]() |
I use a bike security device, does the job and can be painted to blend in. All the ugly bits hide behind the wheel out of sight
Cheers Paul Monty-2015 2.2 110 XS Puma Station Wagon Yoda Disco 3-Sold Larry Disco 1-Sold Muddly XS 90 TDCI-Sold Pearl Disco 2-Sold Larry Disco 1-didn't want too but sold |
Edzi Member Since: 20 Sep 2015 Location: London Posts: 279 ![]() ![]() ![]() |
Exactly my thoughts ![]() |
Cheers ![]() |
It depends on your wheel and carrier design, I have a swing away carrier with alloy wheels.
2 foot should be enough, use a bit of string to measure the required length before going shopping, i went for a combination lock to speed up removal and cut the risk of forgetting or loosing the keys it needs to be flexible ![]() Yoda Disco 3-Sold Larry Disco 1-Sold Muddly XS 90 TDCI-Sold Pearl Disco 2-Sold Larry Disco 1-didn't want too but sold |
This one is approximately 1.5m and does the job... ![]() Any longer and it would be too long, any shorter and you may struggle to comfortably fit it... ![]() I also have a plastic covered one, which is currently indisposed... ![]() ![]() Click image to enlarge Rog... ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
The bike chains aren't especially cheap ( for a good reason) so why not just invest that money on the elegant solution to start with?
I bought this off eBay and fitted it, looks really nice, I also back it up with 3 locking wheel nuts. ![]() Click image to enlarge ![]() Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Assume that will only fit on ex-factory type wheel carriers...
![]() Admittedly more elegant though... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
I am confident it can be fitted to a Mantec wheel carrier or similar, it just needs adjustment via the washers for the depth. 2016 D4 HSE
Ah, that would have been pretty good news...
![]() However, I believe my rim choice may have put the kybosh on that idea... ![]() Well, from looking at your set up and the device itself anyways... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
Cheers ![]() ![]() |
Thanks ![]() It's a Bowler wheel on the standard door carrier for now. |
I have definitely thought of this approach too, but as I may get a wheel carrier in time, and my DIY "skills" leave a lot to be desired, I figured the chain would be a good start until I move forward with future plans ![]() |
You don't need to be a genuis by any stretch for this.
It's only drilling 3 holes, even a monkey can do that! The kit comes with a template that fits over the existing wheel carrier so you can drill the holes in the right place. Simples. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
