![]() | Home > Wheels & Tyres > Spare Wheel Security Chain |
In the middle of the three mounting studs at the rear of the plate is a welded 'box section' that bolts to the carrier pivot arm. You certainly would not be able to fit it to this type of carrier. ![]() Click image to enlarge This will definitely not fit certain types of swing away wheel carrier due to the design of the wheel carrier head. If it is your stated intention to buy a swing away later get a chain in the interim. ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 3rd Nov 2015 10:37am. Edited 1 time in total |
Safari. It may well fit a Mantec I do not know? I didn't have any pictures at present but got one off of Google. The design on this particular carrier precludes the use of your neat solution.
![]() Click image to enlarge The plate is also very thick in comparison to a standard rear wheel carrier. The only way I could add decent looking security was by picking up the two unused holes on the wheel and manufacturing a 3mm stainless steel plate to prevent access to the securing bolts and using a second 3mm stainless steel strap and tamper proof bolts and pinning the rear. Not foolproof but even with the correct tooling if I needed to use the spare the downside is it would take me about 20 minutes to get it off. ![]() Click image to enlarge ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Edzi Member Since: 20 Sep 2015 Location: London Posts: 279 ![]() ![]() ![]() |
You'd be surprised at my ineptitude with a drill ![]() |
