![]() | Home > For Sale & Wanted > [For Sale] Dixon-date Adjustable coupling bracket £120 deliv |
Rsmont92 Member Since: 27 Sep 2015 Location: Bristol Posts: 65 ![]() |
Brand new still boxed £120 delivered
The Dixon-Bate Towing Adjustable Height Coupling provides 200mm of adjustment in 50mm increments. The slider has four pre drilled holes to accept towing couplings with either 2 hole fixing (BS Au 11a) or 4 hole fixing (BS Au24). The slider is simply secured in place by a 19mm diameter steel pin and R-clips (No tools needed!). ![]() Click image to enlarge Last edited by Rsmont92 on 2nd Nov 2015 11:21pm. Edited 1 time in total |
Thanks for that, im sure its the 200mm one I have but will check now
It is the 200mm one i have and ive now changed the photo
Open to offers
jonnyboy Member Since: 15 Oct 2014 Location: Wiltshire Posts: 161 ![]() ![]() ![]() |
"Might" be interested as looking for a solution to push my Maxxraxx bike rack a bit further out from my spare wheel. Currently have what I think is the "standard" LR setup with a 50mm spacer and the rack is still tight against the tyre. Does anyone know how this fixes to standard setup and how far out this will push the towbar and rack
