Home > For Sale & Wanted > [For Sale] Dixon-date Adjustable coupling bracket £120 deliv
Rsmont92
Brand new still boxed £120 delivered
The Dixon-Bate Towing Adjustable Height Coupling provides 200mm of adjustment in 50mm increments.
The slider has four pre drilled holes to accept towing couplings with either 2 hole fixing (BS Au 11a) or 4 hole fixing (BS Au24).
The slider is simply secured in place by a 19mm diameter steel pin and R-clips (No tools needed!).
Post #468873 2nd Nov 2015 10:35pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Edited now you have clarified.
Good luck with the sale Thumbs Up
Post #468883 2nd Nov 2015 10:50pm
Rsmont92
Thanks for that, im sure its the 200mm one I have but will check now
Post #468884 2nd Nov 2015 10:51pm
Rsmont92
It is the 200mm one i have and ive now changed the photo
Post #468890 2nd Nov 2015 11:22pm
Rsmont92
Open to offers
Post #469145 3rd Nov 2015 7:29pm
jonnyboy
United Kingdom 2005 Defender 90 Td5 XS CSW Tonga Green
"Might" be interested as looking for a solution to push my Maxxraxx bike rack a bit further out from my spare wheel. Currently have what I think is the "standard" LR setup with a 50mm spacer and the rack is still tight against the tyre. Does anyone know how this fixes to standard setup and how far out this will push the towbar and rack
Post #469802 5th Nov 2015 5:02pm
