![]() | Home > Puma (Tdci) > Puma gearbox problem |
take it back to the dealer to sort 2.4 90 XS
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
Paul,
Has this problem been sorted by the stealer? What was the issue? |
Don't do nothing to it as it could jeopardise your warranty....do what Grockle said take it back to the dealer
Take it to the dealer
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
We had that after 6 months and 6,000 miles. Synchromech buttered and gearbox changed under warranty. If it's fading it's not going to get any better. Get it in and changed.
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
We had the clutch done at 20,000 miles. Now, at 26,000 and out of warranty, the syncro is starting to play up. Already our one shot at goodwill with the EGR, had to replace the brake vacuum pump ourselves....
Why do I get the feeling that the time spent under the bonnets of various cars in my teens and early 20s is going to come in useful? ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
thanks for the info, much appreciated.
Yesterday while going home, on that long downhill I did the clutch in + shift gears again. This time I noticed that when I put it in 2nd , it seems as if 'something' is engaging, almost like when you are changing gears normally. This does not happen in any other gear, you can feel it's freewheeling all the way. |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
I took it to Hunters in Guildford, and they say it's fine.. I am not so sure, the bloody thing seemed to know it was going into the dealers, and was OK on the short test drive the mechanic gave it. As soon as I get 3 miles away, the problem comes back. Def seems to be the same as NoDo$h and Naks problem. I'm gonna give it another week, and then it's back to Hunters.. Now the fekking thing is prone to kangarooing in 1st and 2nd gear.. EGR issue? It's only done 10,200 miles for fek sake.. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
that's also LR's standard response over here, f%%% stealers! What I do these days is take it to my indie mechanic, he drives it around and notes everything that is wrong. If it is something small that can be fixed he does it, else I then take it to LR and tell them what to replace under warranty. Am also thinking to ask my indie to replace the gearbox oil with something more appropriate to our warmer climate, not sure what crap they put in at Solihull ![]() |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
You should not add Moly to the gearbox. Synchros need a bit of "friction" to work properly. There is a service call or whatever is called about replacing synchros. At this point I think the transmission is quite a piece of
![]() ............................................................. Earth first. Other planets later |
Hmm.. Not sure I agree with the "don't add Moly to the gearbox", used it on loads of gearboxes without problems before.. Anyhoo... I called Land Rover Cust Services earlier, explained the problem, and got the very helpful chap to see if there was any recalls that need to be done to fix the transmission.. The only recall specific item was a Q068, supposed to stop the sluggish performance. He also advised me to take the car back to ANY UK dealer to get the gearbox / transmission sorted. I'll post more when I have spoken to the dealers again. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Paul, do you have an update from the stealers? Mine have given me the usual 'it's normal on a Defender' bs ![]() |
Quick update.... Hunters in Guildford gave me the usual BS from a main dealer, ie, it's perfectly normal, and maybe your driving style needs to change.. That comment really pi55ed me off... The Land Rover techy I spoke to says it's not normal. I've spoken to another dealer, and as my Puma is going in for its first service, I'm gonna get the warranty stuff done in one big lump.. Now the bloody thing has started the dreaded lurching ar 2000 revs... makes me look like a bloody learner driver... Not good... I'm seriously starting to get p155ed off with it.. Never have I had a car under warranty with so many glaring faults. Yeah, people will say its all part of having a Land Rover.. BS, it's bad manufacturing and quality control. If it has faults in the first year, what's it going to be like 4 years down the line with no warranty left? ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Hopefully by then most of the landy will have been replaced part by part. I know I'm counting on this ![]() |
