Home > For Sale & Wanted > [Sold] Set of puddle/footwell lights
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Having a clear out in the garage and have a set if these Land Rover logo puddle/footwell projector led lights.
Brand new boxed
simple 2 wire connection they are about 6cm high and only require a 23mm hole correct hole cutter is included in kit.
Don't know if you can think of any other ingenious uses for them on the motor.
Same as these
http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...WsnS8Z9Lww
£20 inc 1st class p&p 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #468132 31st Oct 2015 5:14pm
seriesonenut
Hi
PM sent
Post #468137 31st Oct 2015 5:42pm
JOW240725
I guess gone now but if not, please message me Very Happy Thank you.
Post #468147 31st Oct 2015 6:14pm
TD5_dan
Will let you know mate if it falls through you have second dibs Thumbs Up 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #468155 31st Oct 2015 6:40pm
TD5_dan
Sold managed to meet seriesonenut and hand delivered them safely. Thumbs Up 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #468293 1st Nov 2015 11:20am
seriesonenut
Hi
Thanks for stopping mid way to meet up. They will soon be the most high tech component on my 200csw!
Richard
Post #468305 1st Nov 2015 12:54pm
What current draw / wattage are these normally?
Post #468306 1st Nov 2015 1:00pm
seriesonenut
Hi
says LED 7 watt each on the box.
Post #468309 1st Nov 2015 1:03pm
If a tap was taken from the interior light via a relay they could be interior light triggered then.
They are nearly 1A though so I'd be inclined not to power directly from it.
Post #468328 1st Nov 2015 4:17pm
seriesonenut
That could be a plan
Just tested them in the dark/fog and they are very good. The are best at the bottom of the door position for brightness, they also look cool as a footwell light. Both locations are challenging to achieve as there is no obvious easy mounting point. Ideally a flat surface pointing down. On a 'car' the door bin would be perfect.
I will have to look again in the daylight to see what can be done.
Post #468345 1st Nov 2015 5:02pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I've got a set, but not yet fitted as I can't find anywhere for them to go?
The door frame bottoms are not wide enough for them, and the door trim is no good either!
So they have been resigned to the dark side of the shed, until some bright spark comes up with a good solution for fitting them!
Watching with interest..... Whistle
Quite like the idea of the footwell. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #468350 1st Nov 2015 5:14pm
Fibreglass. Thumbs Up make a small mould.
Post #468362 1st Nov 2015 5:45pm
seriesonenut
How about this......
http://www.ebay.co.uk/itm/390840485963?_tr...EBIDX%3AIT
The LED unit is 65mm deep, the pod measurements might work.
Post #468369 1st Nov 2015 5:49pm
