![]() | Home > In Car Electronics > 13 pin trailer electrics |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20692 ![]() ![]() |
Replace the plug on the trailer?
It's probably the curly umbilical cable that has caused wear it transit with its pulling motion. I assume it's a Agri style trailer as these are to make sure the cable doesn't trail low down and get caught. Is it plastic we're talking for socket and plug? |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 ![]() ![]() |
Yep plastic. I have thought about ally type of plug and socket too. And yes the cable is in that respect better then the normal straight cable.
In fact ally type would be an easier swap especially if Hella do ally type....Googling now! |
Hella do make plug and socket in metal. I had only seen Ring which are not quite the quality I wanted!
That may be the way forward. I won't need to use an adaptor for other trailers then! Thanks Steve....overly complicated solution avoided! ![]() |
Wurth do a great 13pin suzzie
Ken - I was trying to think of the proper name of them but couldn't for the life of me remember.
You nailed it. ![]() |
You mean its not called a "Wossname"?
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6653 ![]() ![]() ![]() |
Menbers plugs/sockets are great.
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
The reverse feed is right there in the grey plug so it's not difficult to add to the 13pin plug. As is a pemenant live.
The 13 pin socket will fit in your cross member but only if you rotate it so that the flap can open. I use a Menbers 13pin and am very happy with it. www.td5.org |
