Home > In Car Electronics > 13 pin trailer electrics
kipperthedog
I am having trouble with a trailer plug that is attached to a curly springy cable, it tends to pull the plug sideways giving me intermitantly working side and tail lights on the trailer (obviously this manifested itself when it was dark, making for a fairly stressful journey!).
The socket is a 12 month old Gen LR (Hella) item but the plug is older and a a cheap generic one. I think the plug has worn a bit as it used to be fine.
I could just fit a new, quality plug and replace the crly cable with a normal staright bit. But I woondered whether to fit a more secure 13 pin socket plug but just wire up the 7 pin wires that are already there. However mindful that 13 pin sockets are an MOT test item (I think...), will I come unstuck if I don't wire in the reverse light feed? Anyone know?
If I do this I am looking at Menbers plug/socket as I can't find Hella ones, anyone know if these are of good quality? If not what is?
Thanks Very Happy
Post #468154 31st Oct 2015 7:34pm
Replace the plug on the trailer?
It's probably the curly umbilical cable that has caused wear it transit with its pulling motion.
I assume it's a Agri style trailer as these are to make sure the cable doesn't trail low down and get caught.
Is it plastic we're talking for socket and plug?
Post #468165 31st Oct 2015 8:18pm
kipperthedog
Yep plastic. I have thought about ally type of plug and socket too. And yes the cable is in that respect better then the normal straight cable.
In fact ally type would be an easier swap especially if Hella do ally type....Googling now!
Post #468175 31st Oct 2015 8:56pm
kipperthedog
Hella do make plug and socket in metal. I had only seen Ring which are not quite the quality I wanted!
That may be the way forward. I won't need to use an adaptor for other trailers then!
Thanks Steve....overly complicated solution avoided! Very Happy
Post #468177 31st Oct 2015 9:03pm
Wurth do a great 13pin suzzie
Post #468180 31st Oct 2015 9:08pm
Ken - I was trying to think of the proper name of them but couldn't for the life of me remember.
You nailed it. Thumbs Up
Post #468185 31st Oct 2015 9:32pm
kipperthedog
You mean its not called a "Wossname"?
Post #468191 31st Oct 2015 9:44pm
Martin
Site Admin
Menbers plugs/sockets are great.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #468267 1st Nov 2015 10:45am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
The reverse feed is right there in the grey plug so it's not difficult to add to the 13pin plug. As is a pemenant live.
The 13 pin socket will fit in your cross member but only if you rotate it so that the flap can open.
I use a Menbers 13pin and am very happy with it. www.td5.org
Post #468295 1st Nov 2015 12:29pm
kipperthedog
Thumbs Up Thanks.
Post #468412 1st Nov 2015 8:15pm
