Home > Off Topic > Air instalation |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
I would think the pipe to be fine. It's the fittings, (elbows, joiners, and so on) that I would be concerned about. But it does hold very high water pressure.
29th Oct 2015 7:43pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
I have always been told to avoid pipe like that as it can fracture and explode sending shards of plastic everywhere. You can use metal piping as it can handle the pressures and will not degrade, there is however a company in the states that I looked into as they do a full kit for the workshop and once I checked the prices they offered a very good price even after shipping, I believe they use plastic piping but it was designed to handle the pressure and also the oil that passes through the lines as some always comes out the compressor. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
29th Oct 2015 11:45pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
We use the smc quick release for airlines at work no worries. The pipes rated high enough and the only weakness is the fittings if you connect and disconnect them a lot. Even then they tend to just leak.
They are designed for and used widely for air distribution in industrial machinery http://www.smcusa.com/top-navigation/cad-models/21909 |
30th Oct 2015 1:06am |
One option is JG Speedfit:
http://www.johnguest.com/products/air-and-pneumatics/air/ Tricoflex hose (the nice yellow stuff) is rated for use with air too, that's what we use for all our water hoses but we haven't tried it for pneumatics yet. |
30th Oct 2015 1:01pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
Cheers guys I like the look of the john guest stuff but it exspensive 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
30th Oct 2015 2:52pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Galvanized steel pipe.
30th Oct 2015 3:17pm |
Just ordered cheers guys 600 of your finest later 2015 2.2 tdci hardtop xs
30th Oct 2015 4:11pm |
