Home > Maintenance & Modifications > Quick release lockable steering wheel? |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1720 |
Agree. I could sort something to overcome it, and the gear lock and the pedal lock and the............. But in reality there going to give up and most likely take the td5 xs 90 round the corner which has no extra security and is unlocked most of the time.
Many say it but I can guarantee know body could get my 110 away when its parked at home unless you have a large crane or helicopter, as I havent heard may reports of defenders being airlifted out im fairly happy to put that on here Also even as the owner im not sure mines worth all the bother anyway |
30th Aug 2015 6:48pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
Why would the NRG lock not fit the NRG QR 2.8 or 3.0 upgraded models... They both seem to have a 6 holes base pattern... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
31st Aug 2015 1:28pm |
Thank you for that...
Now I just need to confirm I can use the NRG kit with my new steering wheel... And decide what version of their QR to go for... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
31st Aug 2015 9:17pm |
Edzi Member Since: 20 Sep 2015 Location: London Posts: 279 |
Excellent walk through; thanks This may be a silly question, but I'm very new to this! Is the NRG quick release compatible with Momo steering wheels and boss? |
26th Sep 2015 11:56pm |
Dora Member Since: 12 May 2015 Location: South East Posts: 170 |
Yes, as long as they are the standard 6 hole models.
27th Sep 2015 8:01am |
Thank you kindly
27th Sep 2015 10:54am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
Potentially a daft question, but how many of these keep the indicator self cancel? And as a newb, is this how the parts bolt together
Normally: Splined shaft -> Wheel New Wheel: Splined Shaft -> 6 bolt adapter -> New wheel QR: Splined Shaft -> 6 bolt adapter -> fixed half of QR -> Wheel half of QR -> Wheel When removed -> 6 bolt adapter -> fixed half of QR -> Locking mechanism. Then the other half of the QR boss goes with the wheel? |
27th Sep 2015 10:58am |
miker Most bosses have the indicator cancel pins, if not it's not difficult to drill a couple of small holes and knock in a couple of small roll pins. And yes you have it correct, that's why all the components need to be quite slim so as not to bring the wheel towards you too much. Mine is about (if I recall correctly)just under 3/4" further out.
27th Sep 2015 3:40pm |
Cheers! Hopefully buying one in the next month or so and like to be clued up in advance!
27th Sep 2015 6:15pm |
Wheel Member Since: 28 May 2014 Location: Essex Posts: 233 |
Hi,
Sorry to bring this up again but I'm after some info re; quick release + slim steering wheel bosses. I have a 15 plate 90 and will be fitting a Momo Quark wheel and want the slimmest set up I can get with a quick release and lockable centre. I like the ones shown below with the NRG locking centre. I'd like to know if anyone has bought them in the UK or are they only available from the states ?? Thanks, Mark |
29th Oct 2015 11:15am |
Fogster Member Since: 29 Aug 2015 Location: South West Posts: 3 |
Dora - do you know how thick your 'Sringalex' ally boss was machined down to? I've started machining mine. I've machined the front edge down to the top of the inner boss which contains the splines. Did you machine anything off the back face where the boss has the two pin holes for indicator cancelling?
5th Jan 2017 12:26pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
The new QR bosses from Optimill do not require the adaptor to fit on the column, and are, as far as I know, the slimmest QR bosses by a considerable margin.
Comparison photo of standard adaptor and slim QR boss compared to Optimil QR boss: Click image to enlarge |
5th Jan 2017 1:08pm |
Rup90 Member Since: 23 Apr 2016 Location: Sussex Posts: 32 |
I've just fitted Optimill 48 spline quick release boss and it does not alter the steering wheel distance by any noticable amount and is built like a tank. Very happy.
5th Jan 2017 4:07pm |
Likewise. The monster assembly shown fitted in my pohoto above has now been replaced with the Optimil version, which is much more comfortable to use. Excellent quality.
The only criticism I have of it is that the release knobs are self coloured (unlike the one it replaced on which they are black anodised) which means that I spend a lot of time watching their faint reflection in the windscreen. Not a problem, but black would have been better. |
5th Jan 2017 4:17pm |
