Home > Puma (Tdci) > Secondary Fuse Box & additional power
Smudger
United Kingdom 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Guys,
Looking at the secondary fuse box under drivers seat, according to the legend F4 is not used so I'm thinking of using this to feed a separate fuse box for additional devices. Sensible or should I just go direct to the battery?
Smudger 08 110 Puma Station Wagon
65 Jaguar XF Sportbrake S
99 Elise 111S
Honda XR250
42 Royal Enfield Flying Flea
43 Matchless G3L
Post #466406 25th Oct 2015 3:54pm
K9F
Plenty of information on the forum about auxiliary fuse boxes. It really is personal choice and what you intend using it for and total current draw. I took a separate feed off the 400 amp mega-fuse on the battery and supplied the auxiliary main incoming to the fuse box with a 60 amp fuse. This was the maximum rating for the fuse box and allowed me to add circuits when and if I required to that maximum. Whilst underneath the vehicle and running in the supply cable I also ran in a couple of extra multicore cables at the same time so the cables were already fitted for potential additional circuits.
Fuse 4 is indeed not used but is marked on the diagram as having a rating of only 20 amps, that bank of fuses is protected by a 100 amp link fuse so loading of your installation will have to be considered as you may rupture the 100 amp one if the draw of your fuse box exceeds 20 amps. As stated an independent fuse is better.
Extra cable is the grey multicore on the right hand side. Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #466416 25th Oct 2015 4:13pm
Cupboard
I love seeing people use bootlace ferrules on their wiring. Just so much nicer.
Post #466481 25th Oct 2015 6:41pm
K9F
Thank you. You have a 'keen eye' Cupboard. Thumbs Up
I am fortunate enough to have all the tooling and parts I need to do a good job that placates my mild OCD. I personally hate the automotive yellow/blue/red in-line spliices so commonly used. I use Hellerman Jiffies that with the correct insert/extract tool can be subsequently disconnected and reconnected if desired or Amphenol ones if it's a 'one shot job,' they are also hermetically sealed.
Thumbs Up
Post #466489 25th Oct 2015 6:56pm
