Home > Technical > Reverse light
BossHog
Reverse light
The reverse light on my puma 90 works sporadicly it's a MY12 is there a known reason/fix, when it does work it's not very good even though its an LED. I'm considering two rear work lights for practicality, I don't really like the look though needs must, can anyone recommend a good wire through bolt type LED light.
Thanks
Post #466436 25th Oct 2015 6:08pm
Cupboard
Post #466474 25th Oct 2015 7:24pm
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
Double Labcraft scene light means problem solved; in fact I probably now have more light going backwards, than most people have going forwards Whistle "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #466568 25th Oct 2015 11:24pm
BossHog
Thanks for the link, I wasn't aware of the scene light, think that's the way to go.
Post #467685 29th Oct 2015 10:07pm
You might want to make sure that the reversing light switch is properly screwed into the gearbox. It's not unknown for it to be loose, in which case the light will be intermittent.
Post #467718 29th Oct 2015 11:39pm
BossHog
BW thanks for that I will check the switch, now I know where to look!
Post #468028 31st Oct 2015 9:51am
