Home > Td5 > Fuel Filter Head
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Fuel Filter Head
Typically, last item on the service list - replace the fuel filter and it all goes wrong. trying to unscrew the filter from the head and the whole thing came off in my hand. As below, the head seems to have corroded away.
Looking online the cheapest genuine part I can find is;
http://landrover.shukersparts.co.uk/fuel-f...00020.html
Searching here it seems all the heads are interchangeable for the td5. Mine is a very late 06 with no water sensor anyway. Does anyone know of a cheaper genuine part?
Also, I've never had to fetch those td5 push fit fuel connectors apart. How do they work? As in, how do I remove them from the old filter head and then reconnect them to the new head?
Post #466358 25th Oct 2015 11:28am
barbel jim
Slacken the bolts off a tad, and use a cable tie to pull the mounting plate back together, re tighten bolts sorted short term Thumbs Up
Post #466360 25th Oct 2015 11:37am
Freypal
Not a bad idea, was thinking how to secure it short term. I'm guessing this is a common problem. Alloy just looks like its been poorly protected and has oxidised away.
Post #466361 25th Oct 2015 11:39am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Throw some oversized flat washers on the bolts that way it will still hold in place no need to get a new one. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #466380 25th Oct 2015 1:33pm
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
The pipes have catches in them that need to be squeezed together to get them off. They are quite fiddly if you have banana fingers like me. I used a pair of wire strippers - the type with the ends at 90 degrees, to squeeze mine in. I put a bit of tape around the two outer pipes to ensure I replaced them in the correct position. If you buy a new one you will probably have to transfer the non return and air bleed valves in the pipe connectors. I did mine the other week as the old one was leaking and looked like it had been chewed by mice. I used a head designed for an earlier model on my 2005 110. Bought the head and filter from Maltings Offroad from their Ebay shop with next day delivery. Allmakes brand with filter for £110 all in. Took less than an hour all in including removing and replacing the wheel and bleeding afterwards.
Post #466388 25th Oct 2015 2:20pm
Freypal
Thanks chaps. Unfortunately I cant use oversized washers, when I unscrewed the bolts the filter head completely disintegrated. It was incredibly brittle.
For now its held up with cable ties and wedged against the filter cover.
I'll order a replacement and look at getting it done asap.
Post #466389 25th Oct 2015 2:26pm
Swac3
Did mine on the TD5 a week ago, 130 quid from LR main dealer with the pipe fittings nrv and air filter thingy and a fuel filter. As said the pipe clips can be fiddly but squeeze the sides and push in/pull out and they will come off,
I used copious amounts of brake cleaner to get all the crap and grime off everything before removing the pipes and again inside the push fit bits as they were full of crap before connecting it all up.
Edit:
OH, forgot to say, check the location of the pipes on the new head, as they're not always in the right holes, I'd seen mention of it online but even the main dealer parts guy said to check, and... they were wrong. They were also all loose which he had mentioned. 3 Landrovers
Post #466394 25th Oct 2015 3:27pm
Freypal
Thanks chap. I'd read the same.
On yours was it the NRV and bleed valve that were in the wrong unions?
Post #466432 25th Oct 2015 5:03pm
4RF RDS
Just finished undercoating my 2000MY 110 yesterday. I want to try to stay ahead of these silly issues... Good luck with your repair.
1967 MGB GT
Post #466438 25th Oct 2015 5:13pm
Freypal
Thanks mate. Funnily enough I have also ordered a dinitrol kit as well today for the same reason! Need to stop it now, I know too well the implication of leaving it too long. Had to do a lot of welding on my old 200tdi 90.
Post #466448 25th Oct 2015 5:32pm
Swac3
The air bleed was ok, but the NRV was in the right hand side nearest to you as you look into the wheel arch.
So you could look right through the two pipes nearest the chassis. 3 Landrovers
Post #466464 25th Oct 2015 5:49pm
Freypal
If I understand right, the bleed valve should be in the pipe closest to you as you look at it and pointing the rear of the car and the NRV should be furthest pipe away pointing the rear of the car?
Post #466468 25th Oct 2015 5:57pm
Freypal
So new genuine part arrived today and like stated it does appear the valves are in the wrong lines!
Post #467405 28th Oct 2015 9:03pm
dorsetsmith
air bleed valve red arrow
Post #467418 28th Oct 2015 9:37pm
Freypal
Cheers, and the NRV is in the one immediately behind it?
Post #467481 29th Oct 2015 10:04am
