![]() | Home > Technical > Clutch biting with pedal close to floor |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2058 ![]() ![]() |
John, you've probably seen this post, but if not then does any of this help?:
http://www.defender2.net/forum/topic34529....adjustment |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 ![]() ![]() ![]() |
Hi Daz, Yes I had seen that one and copied it and gave it to the dealer once before, I'll probably do the same again but I am still very curious if others have had these strange cluches fitted. 2.2 90 XS
88" Series One Old Norton ![]() Minerva |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
^^^A couple of carefully ground down open end 13mm spanners, and some adjustment at the master cylinder rod
Will see you get a normal clutch pedal again. It's NOT the clutch. When I replaced my clutch it was just the same as yours. I can't believe the dealer couldn't sort it....muppets ![]() Wanted, Forward Control Anything considered. |
Hi Ian,
Doesn't that just change the position/amount of pedal movement rather than the clutch operation? Thanks, John 2.2 90 XS 88" Series One Old Norton ![]() Minerva |
Hi John
Very small amounts of adjustment will make a big difference to the way the clutch will operate, 2mm either way will see pedal travel change. Has the master cylinder been changed? Nearly all Defender/ Discovery clutches I have changed have needed "tweeking" on the M/C rod to get a good clutch pedal. Also, have you got the washers fitted on the rod? I've seen people put these back together minus the washer. This can make a huge difference in pedal travel. You also need a very slight amount of play between the 2 nuts in order for it to be free. It sounds as your M/C is not pushing back enough to operate the clutch properly. Have a play about with adjustment, backing off, increasing adjustment etc. You will find the correct position eventually. Hope you get it sorted ![]() Wanted, Forward Control Anything considered. |
Tks for the new inputs Ian, wooden tops did something with the master cylinder last time but I would have thought if they'd replaced it they would have had to adjust it correctly? Anyway, had a recce under the bonnet earlier and it looks easy enough to get at so will probably take the cover off tomorrow and see what's there.
Cheers, John. 2.2 90 XS 88" Series One Old Norton ![]() Minerva |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
I Had EXACTLY the same problem... Dealer said it was just the new clutch and would bed in (I.e go away)... So I set the clutch as per the manual (TD5 I think) and it's been fine ever since... Went back to the dealer and said I'd happily show them how to set a clutch pedal correctly... (Don't think they we're overly impressed with that)
Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
Hi Folks,
I found myself having to work in Guildford this morning so arranged to pop in to Hunters for a second opinion on my clutch. They took it for a quick spin, agreed it could use some adjustment and did it there and then, without even an appointment. All free under warranty. So three cheers for Hunters of Guildford - excellent service ![]() ![]() ![]() As for the wooden tops in Pulborough, well they've been in denial about the problem and about the ability to adjust the clutch even though I sent them the instructions on how to do it. Can they really be that incompetent??? 2.2 90 XS 88" Series One Old Norton ![]() Minerva |
Glad you got it sorted in the end..
I would be cairfull using your friends in pulborough ![]() |
