Home > Wheels & Tyres > 110 wheel & tyre options |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 |
Click image to enlarge 285s Puma 110" SW ............................................................. Earth first. Other planets later |
28th Nov 2010 8:51pm |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 |
MK, did you have a suspension lift or spacers to fit the Tyres, or is it all standard, they certainly look the part!
28th Nov 2010 9:29pm |
Those are OME springs (1.5" lift) and adjustable long-travel shoxs. Puma 110" SW
28th Nov 2010 10:32pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
285 will fit on standard suspension
have a play with this it will tell you all you need to now http://www.miata.net/garage/tirecalc.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
28th Nov 2010 10:41pm |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 |
thanks for the site Fekete
John 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
29th Nov 2010 5:57am |
Yes, also a 305 also fits with std suspension. Puma 110" SW
29th Nov 2010 6:13am |
Thanks for the feedback gents! New Tyres is one thing, but a new suspension set up would be another, back to the original thread, can we see some more pictures of wheel and tyre combos for inspiration please?
29th Nov 2010 6:58am |
There is the issue with rubbing between the rear tyres and upper spring mount. So, for 285s, the wheel backspace sould be 0, on 8" wide wheels. In this way you do not rub with either side of the tyre. It is roughly equivalent to std alloys+30mm spacers. Puma 110" SW
29th Nov 2010 7:08am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
IMHO 265 offers the best compromise between looks and off-road capability. 285 is simply too big
29th Nov 2010 7:56am |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
Click image to enlarge 285, 8" steel wheel, no spacers, no rubbing. |
29th Nov 2010 8:18am |
Here you go not a 110 but a 90 with 33/12.50/15 no spacers no rubbing
Click image to enlarge NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
29th Nov 2010 11:53am |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
265*75*16 - 11mm offset ZU's
29th Nov 2010 12:18pm |
[quote="fekete"]Here you go not a 110 but a 90 with 33/12.50/15 no spacers no rubbing
Interesting. Do you have pic showing twisted axles? Puma 110" SW ............................................................. Earth first. Other planets later |
29th Nov 2010 12:31pm |
I too was wondering about twisted axles, I saw several wheel arches being chewed up by oversize tyres at the cross axle section at Peterborough this year
29th Nov 2010 1:31pm |
