![]() | Home > Wheels & Tyres > 110 wheel & tyre options |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
![]() Click image to enlarge 285s Puma 110" SW ............................................................. Earth first. Other planets later |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 ![]() ![]() ![]() |
MK, did you have a suspension lift or spacers to fit the Tyres, or is it all standard, they certainly look the part!
Those are OME springs (1.5" lift) and adjustable long-travel shoxs. Puma 110" SW
285 will fit on standard suspension
![]() have a play with this it will tell you all you need to now http://www.miata.net/garage/tirecalc.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 ![]() ![]() ![]() |
thanks for the site Fekete
![]() John 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
Yes, also a 305 also fits with std suspension. Puma 110" SW
Thanks for the feedback gents!
There is the issue with rubbing between the rear tyres and upper spring mount. So, for 285s, the wheel backspace sould be 0, on 8" wide wheels. In this way you do not rub with either side of the tyre. It is roughly equivalent to std alloys+30mm spacers. Puma 110" SW
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
IMHO 265 offers the best compromise between looks and off-road capability. 285 is simply too big
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
![]() Click image to enlarge 285, 8" steel wheel, no spacers, no rubbing. |
Here you go not a 110 but a 90 with 33/12.50/15 no spacers no rubbing
![]() Click image to enlarge NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
265*75*16 - 11mm offset ZU's
[quote="fekete"]Here you go not a 110 but a 90 with 33/12.50/15 no spacers no rubbing
Interesting. Do you have pic showing twisted axles? Puma 110" SW ............................................................. Earth first. Other planets later |
I too was wondering about twisted axles, I saw several wheel arches being chewed up by oversize tyres at the cross axle section at Peterborough this year
