Home > Technical > Yellow door card part
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
Does anybody know if you can get the yellow bit on the door card?
I have a couple where the heads have broken and could do with replacing them.
If not has anybody got any alternatives?
Cheers.
On another note I figured out why one door wasn't locking with the central locking!!
Sadly not before I'd take the card off and the actuator out to bench test it!!!!! Whistle 2006 Defender Double Cab- Zambezi Silver
Post #465798 23rd Oct 2015 12:27pm
K9F
Door locking and window issues and the associated breaks in the umbilical cables are very well documented on this forum. No help to you now though! Could have saved you quite a bit of graft perhaps?
Whistle
http://www.defender2.net/forum/topic38394....ow+working
http://www.defender2.net/forum/topic10828....ng+working If you go through life with your head in the sand....all people will see is an ar5e!!
Post #465841 23rd Oct 2015 2:46pm
airpusher
Your not wrong K9F, Thumbs Up
Sadly I traced the wire but just didn't look right into the rubber. I just had a quick look. Embarassed
It's only when I tested the actuator and it fired quickly that I went back and as I pulled it to have a look further into the rubber boot that it just let go!!!!
Must check the other doors now!!
I think I'll be adding a new section for the rubber bit with better wire to take the flex. Join on either side so it doesn't reduce the flex of the section.
On the plus side the inside of the door is now fully covered with Bilthamber! And it all looked good no rust. 2006 Defender Double Cab- Zambezi Silver
Post #465855 23rd Oct 2015 3:10pm
mk1collector
Because the broken wire central locking problem is so common, yesterday i spent some time trying to find the broken wire which turned out to be a dead actuator Rolling Eyes bloody defenders Evil or Very Mad Laughing Ray
My build thread
Post #465857 23rd Oct 2015 3:16pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
I'm looking for those yellow door card bits as well, hopefully they are available somewhere....
Post #465871 23rd Oct 2015 3:46pm
I am fairly sure that the yellow bit is only available as part of the door card, though I have a feeling that the black bit that fits the yellow bit is available.
The yellow bits are rather prone to breaking off and I think that your only option is to glue them back on with a good quality suitable adhesive.
Post #465877 23rd Oct 2015 3:56pm
CDN38
Had a feeling that may be the case. I have a couple broken ones on the doors I am working on.
Post #465880 23rd Oct 2015 3:58pm
airpusher
From searching around, I'm of the same conclusion as Blackwolf.
I think they only come with the door card.
You can get similar studs from eBay with a similar top. I may try them and cut the back off and glue them on to the left of back plate.
If that doesn't work, who knows!!! Big Cry 2006 Defender Double Cab- Zambezi Silver
Post #465894 23rd Oct 2015 4:19pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
I have successfully araldited the yellow back on.
Post #466042 24th Oct 2015 7:29am
