Home > Maintenance & Modifications > Heated Washer Jets
mse
Heated Washer Jets
A while ago i saw a fantastic post on another forum, about heating any washer fluid.
At the time i thought thats a cracking idea if i ever get chance ill do it - needless to say i havent.
I can broadly remember how it was done, i wondered if anyone had tried it (not using electric ones). I understand there is also an LR kit for it, but mainly ROW markets Mike
Post #21497 7th Jan 2010 4:44pm
Cibit
There was a tip in LRO once about extending the washer hoses and running it alongside a radiator pipe or similar, slight pre-heat but probably not very effective. Might stop it freezing totally once we hit -20C Wink 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #21499 7th Jan 2010 5:01pm
mse
Found the one - wrapped copper pipe around the exhaust manifold and around the jet pipe Mike
Post #21502 7th Jan 2010 7:07pm
dgardel
Italy
http://www.sigmaautomotive.com/HotShot/hotshot.php Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #46517 27th Nov 2010 11:24pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
That's pretty groovy. Have you fitted it yet Wink One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #46585 28th Nov 2010 10:09pm
dgardel
Italy
No, my next project is the Webasto Top C Whistle Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #46593 29th Nov 2010 12:07am
mick
It will still freeze at the washer jets when its not in use with the windchill i would have thought.
i
Post #46657 29th Nov 2010 6:57pm
alantd
That product claims to clear the jets with steam. No idea whether it works or not. One that started out as a 2.4 TDCi 110 XS
Post #46669 29th Nov 2010 8:10pm
Laurie
Have you considered the effect of squirting hot liquid onto a frozen screen?
Hope your insurance is good. Rolling Eyes
Post #46681 29th Nov 2010 9:31pm
Grockle
is that a roll back sunroof then d like they used to fit in the seventies Wink 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #46879 1st Dec 2010 8:01am
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
I've got one of these fitted to a Nissan Patrol and it is brilliant at clearing the ice, however the idea that it can clear ice at the jets maybe overstating things.
It heats the water on the way from the tank to the jets so be aware that you need to ensure that the tank doesn't get frozen, once it leaves the hotshot it is cooling down in the tube to the washer jet so you need to ensure that your washer fluid wont freeze in those circumstances too.
So at this point you have probably worked out that you need washer fluid that is always liquid which possibly defeats the idea of the hotshot.
That said if the tubes have got a bit of ice it will clear it and it has an auto setting which fires hot fluid at the screen for a few minutes and clears the big screen on the Patrol and it does look cool to have steaming washer fluid clear the screen instantly.
To the person that questioned whether it will crack the glass, I read that they thoroughly tested the unit in all conditions against all makes of glass.
Post #49053 19th Dec 2010 8:49pm
dgardel
Italy
gnaa gnaa gnaa Mr. Green Mr. Green Mr. Green
:thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #49060 19th Dec 2010 9:15pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
I've just fitted one of these to the Defender, had the same concerns as Sticky but was sufficiently intrigued to give it a go - used it for the first time today. Have left the Defender out tonight so will see how it copes at clearing the windscreen tomorrow. Fitting was fairly straightforward though it took somewhat longer than the vidoe on Youtube! I'll aim to post some pics tomorrow.
Post #49065 19th Dec 2010 9:36pm
mick
Post #49070 19th Dec 2010 9:56pm
dgardel
Italy
cobs wrote:
............... I'll aim to post some pics tomorrow.
I'm waiting for...... Whistle Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #49073 19th Dec 2010 10:08pm
