Home > Maintenance & Modifications > Any tips for fitting replacement windscreen vent pins?
ZeroGravitas
United Kingdom 2005 Defender 110 Td5 XS CSW Java Black
I bought a set of the Nakatanenga stainless steel windscreen pins, but on attempting to fit them, I found that they're 0.5mm wider in diameter than the OEM one I removed, so could not be persuaded to fit! (5.0mm vs 4.5mm)
Anyone had a similar experience? I tried to widen the holes in the hinge, but it seemed more likely that the spot welds on the vent would fail before the hinges got any wider!
Vendor has kindly agreed to take them back for a refund, but I wanted to ask around before I gave up! 110 XS TD5
Post #465519 22nd Oct 2015 3:35pm
Swac3
These are on my list of things to do also, mines a 99 TD5 so interested in the outcome of this, I would offer to measure them but they're so corroded they will need cutting off. 3 Landrovers
Post #465527 22nd Oct 2015 4:20pm
Post #465530 22nd Oct 2015 4:24pm
Swac3
Dingocroft show them as 3/16 or 4.6mm. Odd for Nakatanenga to get it that wrong, and they must have sold some before surely? V strange. 3 Landrovers
Post #465534 22nd Oct 2015 4:36pm
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
Got mine from http://www.defenderdemister.com/vent-panel-hinge/ as mentioned above.
Slotted straight in, no problem.
Post #465575 22nd Oct 2015 6:58pm
ZeroGravitas
I was surprised that they were that different to be honest. I was kinda hoping someone would say "oh yeah, they're all like that, you just need to drift them in with a sledgehammer" but no one else seems to have had a problem.
Might have to give those other ones from Defenderdemister a go, but knowing my luck the one s I get will be 5.0mm diameter again!
Thanks for the help and the link! 110 XS TD5
Post #465602 22nd Oct 2015 8:11pm
Litch
Bought some BP SS ones, fitted perfectly. ONE LIFE, GET IT!
Post #465951 23rd Oct 2015 8:29pm
