Home > Land Rover Customer Relations > Wheel nuts torque - question for Ryan...
ericvv
Ryan, there is a question about correct wheel nuts torque in below copied thread. You may have missed it as it is not posted in the "Customer Relations" section, hence why I copy it here.
It seems that there is conflicting recommendation about this in the Defender manuals for different model years, so I would like you to clarify this with your tech reps. I cannot imagine that wheel torque for one and the same wheel would be different for a 2009 or for a 2015 model.....
Therefore, please provide correct torque for:
A. Standard steel wheels
B. 7 inch alloys, notably Boosts, Dual Tone and Sawtooth wheels
C. 6.5 inch HD Wolf steel wheels
In the unlikely event that there are different torque recommendations for the above for different model years, please say so.....
If you read through below thread you will understand that there is confusion, and we would like to hear what is the correct Nm number from the horses mouth. Thumbs Up
Eric
http://www.defender2.net/forum/topic40932.html?highlight=ryan You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #465327 21st Oct 2015 7:10pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Wolf wheels fitted to wolfs and the ones retrofitted to the earlier 90/110 are torqued upto 170NM
Post #465438 22nd Oct 2015 10:44am
ericvv
I think the question in my OP was very clear, and I was not soliciting any information which even remotely could bring JLR in trouble later. Just 3 simple numbers, which are well defined numbers for each of those original Defender wheels.
I guess Land Rover Customer Relations must have run the question by JLR legal counsel anyway, given this nonsensical response that I got by PM.
If they cannot even give a proper answer to this type of questions..... Rolling Eyes Thud
Not worth getting excited over, better to start Rolling with laughter Rolling with laughter Rolling with laughter
Ryan@LandRover wrote:
Hi ericvv
Thank you for your message.
I note your comments and must advise that the correct torque for your vehicle will be stated in the owners handbook for your vehicle and we would advise consulting the relevant section for clarification regarding this.
Alternatively, you may wish to contact your local Land Rover retailer should you have any queries in relation to this.
Regards
Ryan
Post #468431 1st Nov 2015 9:05pm
keith
Thumbs Up
Post #468453 1st Nov 2015 9:42pm
Retroanaconda
For feck's sake it's a Land Rover not a space shuttle, just do 'em up FT.
My Wolf wheels have been done up to 100 lbs-ft since fitting them, never has one fallen off in the 70,000 miles since.
Post #468470 1st Nov 2015 10:18pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Post #468507 1st Nov 2015 11:22pm
