![]() | Home > Maintenance & Modifications > Outside temperature sensor |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
I just ordered one of these. Cheap as chips!
Pom |
dgardel is your man on this one Here
http://www.defender2.net/forum/topic3998.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
chris h Member Since: 09 Nov 2009 Location: West Devon Posts: 47 ![]() ![]() ![]() |
http://shop.conrad-uk.com/car/car-equipmen...54714.html
I believe this is the one dgardel used. It is reduced from £84.40 to £62.20 - a bargain. Although it looks very smart in dgardel's installation. |
It is ![]() Mine arrived from Conrad UK a couple of weeks ago - just got to get it fitted now. The reason it is expensive is because it can also be connected to the Air Con and used as a form of climate control. Bob |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
how does it do that? ![]() |
No idea - my German is not that good ! This is a link to the Checktemp 2 instruction, I have the CT3 and the instructions are quite different ! http://www.produktinfo.conrad.com/datenbla...emp_II.pdf Bob |
Wow, that could be a very cool toy to have in the landy... but fiddling with the air-con circuit?
shingwell Member Since: 13 Mar 2009 Location: herefordshire Posts: 45 ![]() ![]() |
I use my Scanguage II to display air intake temperature (= outside air temperature when you're moving)
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
I use one of these
![]() ![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
Seems (looking at the instructions, and I'm no electrician!) that the only wire one needs to touch is one of the wires going to the aircon switch.
The Checktemp then takes over control of this cicruit/switch, turning the aircon off and on to maintain the right temperature. If this is correct then it's not quite a proper climate control system. Or am I missing something?
![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
